Upgrading Fuel Delivery System...
Posted: Tue Jul 09, 2002 12:55 pm
Ok guys I have some questions. This Thursday I will be starting to
upgrade my fuel delivery system. I am doing this because I will be
placing a larger turbo in the car and increasing the boost past 13
psi. I
am also under the impression that with the car over boosted to 13
psi the
stock fuel pump is too small and the car is already running lean.
Here is
what I
am considering for Thursday.
Holley 255 High Pressure Fuel Pump.
AEM Fuel Pressure Regulator.
Later down the road....
550cc injectors.
Engine management system.
Bigger turbo
Once the new parts are in the car, it will then take some runs on the
dyno. I will be placing the fuse into the FWD/AWD slot in the engine
bay as the dyno is not AWD. Has anyone run their car on the dyno
using
this FWD trick? What size fuse should I use?
So let me have it!
Current mods on the car so you know background.
STI engine mounts
IC off 95 WRX
2.5' Custom exhaust with 2.5' down pipe, high flow cat, reactive
muffler
Boosted to 13psi, Autometer boost guage.
KYB struts with Whiteline Legacy Select Springs
K&N filter (wow feel the power
) with 'snorkus' removed
17' primax rims covered in Falcon GBR tires.
and yes it is still a crappy auto
-Adam
92 Legacy turbo Sedan
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/TPvn8A/PfREAA ... /XoTolB/TM
psi. I
psi the
Here is
what I
550cc injectors.
Bigger turbo
using
So let me have it!
STI engine mounts
IC off 95 WRX
muffler
-Adam
Risk Free!
