will this clutch fit??? help please
legacy32656
Post by legacy32656 »
i have a 90 subaru legacy 2.2 wagon. which is going to become a turbo car. in a few months. i cam acrossed a monster clutch cheap will it work it cam off a legacy twin turbo rs. he says it "It will fit all turbo subarus that have a pull style hydro clutch." is this what the 90 legacy have? so will it work or not any info glady apperciated....
thanks brian
DLC
Post by DLC »
The Turbo Legacy and WRX share the same transmission design, which is also shared with the Twin-Turbo overseas models.
Your transmission is not this type, it's not even hydraulic, so unless you're replacing the transmission as well, it will not fit.
Legacy Central
submannz
Post by submannz »
You will just have to uprate your pressure plate, as mentioned here the clutch types need the equivalent bell housing which is part of the gearbox housing also.
JasonGrahn
Post by JasonGrahn »
matter of factly, the transmission housings are the same between the turbo and non-turbo. If you change the pivot point that the clutch fork sits on, you should be able to use the turbo-type clutch.
granted, from my understanding, you'll also need the hydraulic assemblies to go with it. ;)
-Jason Grahn
If you need a pressure plate, there's one on eBay:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2416159536
Brat4by4
Stratified
Post by Brat4by4 »
i believe that's the one he is talking about all along.
legacy32656
thats the one .. its is on ebay
