OK - been at this for a little while now, and need to some real info from those in the know (as my dealership guru is out to lunch!)
KYB lists only GR2's as being available for a 1991 Legacy Turbo, no AGX's. They do list AGX's for the 92 and onwards Legacy turbo, with the same part numer as the 93 and onward Impreza AWD models.
I have "heard" that the fronts are all interchangeable from 1991 onwards between Legacy and Impreza. I also "heard" that in order to use the rear AGX's, you need only to fit the rear ounts ineded for a GC8 (apparantely they bolt in place of the 91 mounts, but the seat where the spring sits is a different diameter, thus allowing you to use springs for either the later (92 and up) Leagcy or the Imprezas (93 and up), of which there are almost endless companies
Can someone, anyone, confirm or deny any/all of the above, or let me know their year car, 2WD or AWD and what suspension combo (spring strut) they are using please. I am trying to get this info down pat for my own car, and also add to our forthcoming Legacy section on our website.
Thanks in advance guys!
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
91 Legacy turbo suspension (again!)
