Got my TMIC on today. Saab set up
Posted: Thu May 22, 2003 1:19 am
by GizMo22t
It is about 6:00pm and I have been working on the IC for about Three hours or so. I purchsed the IC for $25 form a guy I know in Ft. Collins. After much deliberation I decided on how I could get the IC to work. There was some cutting and JB Welding but not much. The inlet had to be cut and turned around 180Degrees. I got the pipe cut and the JB weld on last night so I could get it done today. I do have a picture of the finished job but I need someone to host. The only thing I still have to figure out is how I am going to mount the BOV. Total cost of the project was around $50 or so. That is only because of the low cost of the IC. If you have any questions feel free to ask
Posted: Thu May 22, 2003 1:36 am
by JasonGrahn
aHHHH!!! JB WELD?!?! ON A PRESSURIZED PIECE?
Have fun!
Posted: Thu May 22, 2003 1:45 am
by GizMo22t
JB weld worked on my buddies BOV and he was pushing 20psi so I think that I'll be good with 10psi
Posted: Thu May 22, 2003 1:58 am
by JasonGrahn
To each their own.
Just heed the immortal words...
Go For It!
Posted: Thu May 22, 2003 2:16 am
by magicmike
stupid question......whats a JB weld?
Posted: Thu May 22, 2003 2:36 am
by JasonGrahn
http://www.jbweld.net/
good for temp fixes IMO.
Posted: Thu May 22, 2003 2:44 am
by 91White-T
I've had a piece on my saab IC JB welded since last august and pushing upwards of 15psi.... you should be fine.
Posted: Thu May 22, 2003 3:50 am
Properly applied, JB-Weld is supposed to have a tensile strength on the order of 4,000 psi. If you do it right, it's almost as good as a good weld with decent rod.
Posted: Thu May 22, 2003 3:46 pm
by Fernely
I will post up a pic of my Saab IC with my temporary pipe and how I pu the Recerculating valve in. I should have it up some time this afternoon.
Posted: Thu May 22, 2003 5:27 pm
by GizMo22t
Ok thanks that should be helpful. I still need someone to host the pic's I have.
Posted: Thu May 22, 2003 5:37 pm
by morgie
send them to me, i'll host them
nicvallee@sympatico.ca .just make sure your mail dont exceed 3mb and it will be fine
Posted: Thu May 22, 2003 6:56 pm
GizMo22t wrote:Ok thanks that should be helpful. I still need someone to host the pic's I have.
I've emailed you the links to post for your pics.
Posted: Thu May 22, 2003 9:37 pm
by GizMo22t
Josh: I'm sorry can you E-Mail me that link again I must have deleted the mail by accident. Thanks
Posted: Fri May 23, 2003 12:31 am
Posted: Fri May 23, 2003 7:45 am
by GizMo22t
Thanks Josh Here is the pic if you didn't click on the link.
Posted: Fri May 23, 2003 1:58 pm
by 91White-T
I've got the exact same setup, and just to let you know, make sure that the IC clears the coolant tank lines on the back. Mine didnt and broke off in a matter of weeks, especially if the coolant tank is older and more brittle.
Posted: Sat May 24, 2003 1:12 am
by GizMo22t
Thanks for the Info I'll keep an eye out. Do you have any problems of it rubbing on the fire wall?
Posted: Sat May 24, 2003 2:11 pm
by 91White-T
It actually rests right up against the firewall, the coolant thing is the only problem its caused, other than that its a pretty damn good fit...
Posted: Sat May 31, 2003 12:21 pm
by Fernely
OK i was real busy last week, my wife had our second baby a beautiful girl. Here is the shot of my temporary set up. I need to get to the custom shop I use and get the proper pipes bent. I'll post more about it in a few weeks.
Posted: Sat Sep 20, 2003 8:59 pm
by LegacyT
GizMo22t:
How does the engine run without the recirc-valve plumbed up?
Mark,
Posted: Sun Sep 21, 2003 4:24 am
by -K-
You should unbolt the coolant tank and turn it kinda sideways. Maybe
zip-tie it out of the way, then it won't break.
Posted: Sun Sep 21, 2003 12:46 pm
by LegacyT
How did you clear the brake booster reservior? Also did you cut the outlet end of the intercooler off - or just place it into the throttle body? And finally how did you clear the lines coming out of the coolant tank?
Thanks,
Mark
