Got my TMIC on today. Saab set up
It is about 6:00pm and I have been working on the IC for about Three hours or so. I purchsed the IC for $25 form a guy I know in Ft. Collins. After much deliberation I decided on how I could get the IC to work. There was some cutting and JB Welding but not much. The inlet had to be cut and turned around 180Degrees. I got the pipe cut and the JB weld on last night so I could get it done today. I do have a picture of the finished job but I need someone to host. The only thing I still have to figure out is how I am going to mount the BOV. Total cost of the project was around $50 or so. That is only because of the low cost of the IC. If you have any questions feel free to ask
Mo
93touring wagon
93touring wagon
send them to me, i'll host them
nicvallee@sympatico.ca .just make sure your mail dont exceed 3mb and it will be fine![Smile :)](./images/smilies/icon_smile.gif)
morgie
'98 4Runner V6 Manual 4x4.
I've emailed you the links to post for your pics.GizMo22t wrote:Ok thanks that should be helpful. I still need someone to host the pic's I have.
here
http://www.main.experiencetherave.com:8 ... 0005_4.jpg
http://www.main.experiencetherave.com:8 ... 0006_3.jpg
I've got the exact same setup, and just to let you know, make sure that the IC clears the coolant tank lines on the back. Mine didnt and broke off in a matter of weeks, especially if the coolant tank is older and more brittle.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
How did you clear the brake booster reservior? Also did you cut the outlet end of the intercooler off - or just place it into the throttle body? And finally how did you clear the lines coming out of the coolant tank?
Thanks,
Mark
Thanks,
Mark
