I have KYB AGX struts on my 91 turbo AWD... and i used the ones listed for a 98-01 impreza RS.. i used the stock upper mount and stock springs... no problems. all bolted up, took me 4 hours. not including bleeding the brakes, but the suspension work was 4 hours...
as for ABS and wheel sizes.... i dont count there, i have the gold rims from a 98 impreza RS (to clear the 4 piston calipers) but i also pulled the ABS fuse too! i cant stand the subaru ABS..
mike
struts and ABS question
Z1Auto@aol.com
so you have Impreza AGX's, and stock Legacy turbo springs and strut tops?
how is the ride? Pictures? did you notice anything weird about your springs (such as a taper on the rear springs towards the top?)
thanks!
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
<http://rd.yahoo.com/M=229641.2166546.36 ... debtscape/>
thanks!
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
Josh Colombo
You most likely have a pretty weird proportioning valve setup or split point for the proportioning valve due the fact it was setup for ABS.....but hey if the braking works good.....then no biggie
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com
of beats and rhythm" - ME
-----Original Message-----
From: subaruracer755@cs.com [mailto:subaruracer755@cs.com]
Sent: Wednesday, July 10, 2002 6:24 PM
Subject: [BC-BFLegacyWorks] struts and ABS question
mike
Josh Colombo
mike
