Which is the best BOV could use on the 92 Legacy turbo??
Ben
BOV for 92 Legacy turbo?
If you're not fussed about making the whoosh noise then get a recirc type like a Forge recirc or if you want the noise without the associated problems with vent to atmosphere types (bad idle, rich etc) then go for turbo xcess which recircs on lower pressures and do both atmosphere and recirc on higher pressures.
I would like the one as like the OEM style, which is the best and
where could I find it??
Ben
Ben
I think someone once mentioned that a Bosch BOV used on the 911 turbo
could be used, and would work better. I think Bill Covert or Larry
Witherspoon has one of these.
This is Bill C. I used the Bosch(Porsche) BOV with my old air to air
intercooler setup.They are cheap,about32$ at the Porsche dealer. They seem
to work well and flow very well. It is essentially the same unit Turbonetics
sells for twice the cost.It has a 90 degree angle between the in and out
fittings. They are also 1" hose connectors. If you need the part# for the
Porsche dealer I can get it out of my filing cabinet and post it.Good Luck,
BillC
BillC
