Some interesting info on Lower Chassis Braces for the BC/BF from
Whiteline..For those in the USA, I guess this part is available via
MRT dealers, and should be more readilly available / less expensive
than the rare Cusco part.
Wojtek,
Thanks for the quick reply. I'll post this info on the Liberty RS
Turbo group, and BC-BF Legacyworks and see if Someone from Sydney can
come over & try one. Thanks for the quick reply
Regards
Stuart
Wojtek Rogulski <wojtek@whiteline.com.au> wrote:
Hi Stu,
KSB700 will fit all of the chassis and cross-member mounting points
on the
RS Liberty, as it is same as WRX. But, we are not sure if KSB700 will
clear
the exhaust, and we haven't fitted it to this car to confirm.
If you're a Sydney local, you are welcome to come to our workshop to
try
out.
Regards,
Wojtek Rogulski
Go flat out with Whiteline Automotive
See us at www.whiteline.com.au
Buy online at www.whiteline.com.au/store
Whiteline WRX Lower Chassis Brace
