Removing Intake "Snorkus" from Leagacy Turbo.
I heard that taking out the Intake snorkus out of the fender will help
blow more air and make more sound. What does this part look like and
how do I remove it?
Thanks,
Mark
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/wlyPtD/PfREAA ... /XoTolB/TM
how do I remove it?
Thanks,
Mark
Risk Free!
Here's link for some pics and such
http://www.remarcable.net/misc/legacy_o ... kusectomy/
It's for an outback.......but should give you an idea.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Sunday, July 21, 2002 7:15 PM
Subject: [BC-BFLegacyWorks] Removing Intake "Snorkus" from Leagacy
Turbo.
how do I remove it?
Thanks,
Mark
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Access Your PC from Anywhere - Free Trial
http://us.click.yahoo.com/o5uw2C/0ncEAA ... /XoTolB/TM
Josh Colombo
Turbo.
how do I remove it?
Thanks,
Mark
Those intructions are right on to how I removed mine.
Some suggestions I would make is to not remove the
wheel. I didn't even have to fully remove the cover
on the inside of the cover nor did I even jack up the
car, though it would give you a little more room. The
clips for the cover are definetly not easy to get off
but will come off. Make sure and reset the ECU
correctly as I have heard that not doing so can cause
Check Engine lights to come on. The one other thing I
did was to remove the factory air filter box and where
the snorkus plugged in there is a rubber O-ring the
gave it a clean connection. It is only about two
inces in diameter so I cut it out to enlarge the hole.
It doesn't give it much more noise, mainly between
3-4K RPMs, but definetly seems to improve performance
a bit. Good luck.
Grant
> idea.
> Josh Colombo
> From: c150cglzp [mailto:c150cglzp@yahoo.com]
> Turbo.
> part look like and
> how do I remove it?
> Thanks,
> Mark
> to:
__________________________________________________
Do You Yahoo!?
Yahoo! Health - Feel better, live better
http://health.yahoo.com
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/O3jeVD/R_ZEAA ... /XoTolB/TM
a bit. Good luck.
Grant
> idea.
> Josh Colombo
> Turbo.
> part look like and
> how do I remove it?
> Thanks,
> Mark
> to:
Do You Yahoo!?
Q1:
Have Any kiwis/Aussies who drive jap-import EJ20T legacies performed this
procedure? Is it identical for our spec. Legacy?
At a casual glance my air intake/snorkus looks different from in the
pictures provided by Juice. Maybe because its a Forester?
BTW - I am now on a mission after driving Adrians (aka adriatic75) legacy
during the weekened my EJ20T touring wagon feels like a 1973 Holden
Kingswood in comparison. And so my upgrade journey begins in earnest.
Q2:
Does anyone out there have any tips for improving performance specific to
4-speed auto touring wagons? I know, I should have got a manual...
My number one pain is the autobox, I lose out on the engine braking that a
manual tranny provides to assist roadholding/braking, also it does not like
to be "manually" shifted through the gears. I do like the "manual" button
though on tight roads.
Number two is the handling, currently every little bump seems to rattle the
car (tyre pressure is OK tho) whereas at speed cornering is average at
best. I would like the opposite, eg smoother ride but better cornering.
Thanks in advance for any tips for a mechanical novice
cheers
Paul
Auckland NZ
Have you seen our website?.... http://www.vodafone.co.nz
CAUTION: This correspondence is confidential and intended for the named recipient(s) only.
If you are not the named recipient and receive this correspondence in error, you must not copy,
distribute or take any action in reliance on it and you should delete it from your system and
notify the sender immediately. Thank you.
Unless otherwise stated, any views or opinions expressed are solely those of the author and do
not represent those of Vodafone New Zealand Limited.
21 Pitt Street, Private Bag 92161, Auckland, 1020, New Zealand
Telephone + 64 9 357 5100
Facsimile + 64 9 377 0962
http://us.click.yahoo.com/7dY7FD/R_ZEAA ... /XoTolB/TM
Q2:
cheers
Paul
Auckland NZ
I swear all our ears must burn at the same time.
Yesterday AM, I woke up, and my brotehr and I remvoed the silencer/snorjus thingy fro the fender well on my 91 Turbo..took all of 10 minutes to do, made slightly more noise with my K&N drop in filter, but nothing too big...a bit of a boost mid range though
Tomorrow is the day of truth...suspension goes in ! (Tein springs, Sti top mounts front and rear, and KYB's)..now I can make decent usage of the Yokohama A520's I have on there!
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.35 ... 6-1039-302>
Adam
Z-1 Performance
www.z1auto.com
(631)254-8277
ADVERTISEMENT
Paul,
For the autobox, about the best thing I can suggest is to get the valve
body rebuilt, and put a shift kit in it. I'm going to be doin this next
week some time, and can let ya know how it turns out.
The manual button does nothing for performance. When depressed, the ECU
keeps the tranny from going into 1st gear, and the car starts off in 2nd
gear. This is supposed to help reduce torque to the wheels and reduce
wheel slip. This feature only works when the gear selector is
physically in the 3 or 2 position. When in 3, the tranny selects ONLY
between 2 & 3. When in 2, the tranny will stay in 2nd gear. When in
1st, it does nothing for the gear selection. The one press release I
have says it does make a more aggressive AWD map. So you may get 50/50
split all the time, rather then the normal 90/10 that the auto has.
Suspension.....what tires you have on the car? Size? Wheel size? Tire
pressure? Etc...
Josh Colombo
From: paul.travers@vodafone.co.nz [mailto:paul.travers@vodafone.co.nz]
Sent: Monday, July 22, 2002 4:45 PM
Subject: RE: [BC-BFLegacyWorks] Removing Intake "Snorkus" from Leagacy
Turbo.
Q1:
this procedure? Is it identical for our spec. Legacy? At a casual
glance my air intake/snorkus looks different from in the pictures
legacy during the weekened my EJ20T touring wagon feels like a 1973
Holden Kingswood in comparison. And so my upgrade journey begins in
earnest.
Q2:
to 4-speed auto touring wagons? I know, I should have got a manual...
a manual tranny provides to assist roadholding/braking, also it does not
like to be "manually" shifted through the gears. I do like the "manual"
button though on tight roads. Number two is the handling, currently
every little bump seems to rattle the car (tyre pressure is OK tho)
whereas at speed cornering is average at best. I would like the
cheers
Paul
Auckland NZ
recipient(s) only. If you are not the named recipient and receive this
correspondence in error, you must not copy, distribute or take any
those of the author and do not represent those of Vodafone New Zealand
Limited.
21 Pitt Street, Private Bag 92161, Auckland, 1020, New Zealand Telephone
+ 64 9 357 5100 Facsimile + 64 9 377 0962
Risk Free!
http://us.click.yahoo.com/NsdPZD/PfREAA ... /XoTolB/TM
pressure? Etc...
Josh Colombo
Turbo.
Q1:
earnest.
Q2:
cheers
Paul
Auckland NZ
Limited.
Risk Free!
I would also like to know if any of this has been done to NZ cars. Hopefully you and I can do the procedure together Paul
----- Original Message -----
Sent: Tuesday, July 23, 2002 103 AM
Subject: RE: [BC-BFLegacyWorks] Removing Intake "Snorkus" from Leagacy Turbo.
Q1:
pictures provided b
ADVERTISEMENT
_____
Get more from the Web. FREE MSN Explorer download : http://explorer.msn.com
Q1:
pictures provided b
ADVERTISEMENT
_____
thanks Josh. Will be interested to hear how your shift kit turns out. My
girlfriends dad owns not 1 but 2 (!!!) Dodge Challengers (rare in NZ), one
is manual but the other auto with shiftkit which definitely does the job.
My wheels are standard 205/60/R15. Tyres are average quality
non-directional Dunlops (fitted by previous owner). I inflate to 32/33 PSI
which the tyre shop guy said was about right.
Adrian - snorkus project sounds like a plan
cheers
Risk Free!
cheers
Risk Free!
I will let ya know how it goes. I'll also be installing a tranny cooler
as well.
I've never been a real fan of the dunlops.....they sucks....IMO. Those
are reasonable tire pressures......you could try runnin a tad higher in
the front....maybe 33-35, and leave the rears alone, or drop a psi or
two.
Josh Colombo
Sent: Monday, July 22, 2002 5:20 PM
Turbo.
My girlfriends dad owns not 1 but 2 (!!!) Dodge Challengers (rare in
NZ), one is manual but the other auto with shiftkit which definitely
does the job. My wheels are standard 205/60/R15. Tyres are average
quality non-directional Dunlops (fitted by previous owner). I inflate
to 32/33 PSI which the tyre shop guy said was about right.
cheers
Limited.
Risk Free!
as well.
two.
Josh Colombo
Turbo.
cheers
Limited.
Risk Free!
thanks again, and I agree they suck! 2 of the 4 will be ready to replace
in a few months, will go for some directional tyres, maybe bridgestones.
"Josh Colombo"
<josh@surrealm To: <BC-BFLegacyWorks@yahoogroups.com>
irage.com> cc:
23/07/2002 Leagacy Turbo.
11:17
Please respond
to
BC-BFLegacyWor
ks
as well.
two.
Josh Colombo
Turbo.
cheers
Limited.
ADVERTISEMENT
zZz.
"Josh Colombo"
irage.com> cc:
11:17
Please respond
to
BC-BFLegacyWor
ks
as well.
two.
Josh Colombo
Turbo.
cheers
Limited.
ADVERTISEMENT
zZz.
Since you have AWD.....you need to replace all 4 tires at the same time.
You need to keep the rolling diameter the same so you do not fry the
center diff and transmission.
Kumho's, Ecsta 712 are supposed to be pretty good and not very
expensive. I've heard good things about them....have heard they may
have small issues with being perfectly round.....not sure......I haven't
had any direct experience with them, but am considering them for my next
tires.
Josh Colombo
Sent: Monday, July 22, 2002 6:23 PM
Turbo.
replace in a few months, will go for some directional tyres, maybe
bridgestones.
"Josh Colombo"
<josh@surrealm To:
irage.com> cc:
Subject: RE:
11:17
Please respond
to
BC-BFLegacyWor
ks
as well.
two.
Josh Colombo
Turbo.
cheers
Limited.
ADVERTISEMENT
zZz.
Limited.
Risk Free!
tires.
Josh Colombo
Turbo.
bridgestones.
"Josh Colombo"
<josh@surrealm To:
irage.com> cc:
Subject: RE:
11:17
Please respond
to
BC-BFLegacyWor
ks
as well.
two.
Josh Colombo
Turbo.
cheers
Limited.
ADVERTISEMENT
zZz.
Limited.
Risk Free!
ASee, and having driven Subarus with teh Kumhos, I HATE them with a
passion...right up there with NItto IMHO.
To datem the best tires I ahve used on the Subarus (Legacy Turbos and Impreza
GC8 and WRX GDA are (in order):
Pirelli P Zero Asymetrico
P Zero Rosso (only used on WRX GDA)
Bridgestone Pole Position S)3
Yokohama A520
Toyo Proxes T1S
Falken Azenis (good tire, sumemr only, next to no tread life though)
Sumitomo HTRZII (best bang for the buck tire out there IMHO for the car)
Yokohama Parada (have yet to try the new spec 2).
Admittedly, many the above are pricier tires, but all work VERY well.
Remember, jsut because a tire gets a favorable rating from a magazine,e tc.,
does not mean it will work well on your car...suspension setup, wheel weight,
wheel diameter, etc. all make a HUGE difference in how well the tires work.
The above is what we haev found from years of working on these cars, but most
of my experiences have been with 17 inch sizes.
Risk Free!
Yokohama A520
Toyo Proxes T1S
Risk Free!
Back to the snorkus. I am sorry for the pictures I just sent but thought they might be to small if I posted them. Hopefully this should help everyone.
Sent: Tuesday, 23 July 2002 1:32 PM
Subject: Re: [BC-BFLegacyWorks] Removing Intake "Snorkus" from Leagacy Turbo.
Yokohama A520
Toyo Proxes T1S
Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service.
<http://us.a1.yimg.com/us.yimg.com/a/le/ ... 68x60b.gif>
Click here to find your contact lenses! <http://rd.yahoo.com/M=225674.2075965.36 ... xpress.com>
Yokohama A520
Toyo Proxes T1S
By the way I did’nt do mine like that I placed it in the guard. By the way I live Australia and it works fine.
From: Douglas Hancock [mailto:douglashancock@optusnet.com.au]
Sent: Tuesday, 23 July 2002 10:28 PM
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
Yeah......that's what I'm going to be doing too.
Doug,
You happen to have some higher res pics of that article you could email to me?
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com
Sent: Tuesday, July 23, 2002 7:34 AM
Yokohama A520
Toyo Proxes T1S
Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service.
ADVERTISEMENT
Doug,
Josh Colombo
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
I would recomend Falcon tires, they are to expensive and they work
really well. My 2 cents
-Adam Archibald
time.
haven't
next
> tires.
> Josh
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
> From: paul.travers@v... [mailto:paul.travers@v...]
> To: BC-BFLegacyWorks@y...
Leagacy
> Turbo.
> bridgestones.
> "Josh Colombo"
> <josh@surrealm To:
> <BC-BFLegacyWorks@y...>
> irage.com> cc:
> Subject: RE:
> 11:17
> Please respond
> to
> BC-BFLegacyWor
> ks
cooler
> as well.
Those
higher in
or
> two.
> Josh
> Josh Colombo
Leagacy
> Turbo.
out.
inflate
> cheers
named
this
and
Zealand
> Limited.
Telephone
> BC-BFLegacyWorks-unsubscribe@e...
> ADVERTISEMENT
> zZz.
named
this
and
Zealand
> Limited.
Telephone
-Adam Archibald
time.
haven't
next
> tires.
> Josh
> Josh Colombo
Leagacy
> Turbo.
> bridgestones.
> "Josh Colombo"
> <josh@surrealm To:
> irage.com> cc:
> Subject: RE:
> 11:17
> Please respond
> to
> BC-BFLegacyWor
> ks
cooler
> as well.
Those
higher in
or
> two.
> Josh
> Josh Colombo
Leagacy
> Turbo.
out.
inflate
> cheers
named
this
and
Zealand
> Limited.
Telephone
> ADVERTISEMENT
> zZz.
named
this
and
Zealand
> Limited.
Telephone
Correction "I would recomend Falcon tires, they are to expensive and
they work really well.". I ment to say 'I would recomend the Falcon
GBRs or the Ariez. They have both worked very well for me.'
-Adam Archibald
> -Adam Archibald
same
> time.
the
may
> haven't
my
> next
> > tires.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> > bridgestones.
> > "Josh Colombo"
> > <josh@surrealm To:
> > irage.com> cc:
> > Subject: RE:
> > 11:17
> > Please respond
> > to
> > BC-BFLegacyWor
> > ks
> cooler
> > as well.
> Those
> higher in
psi
> or
> > two.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> out.
in
definitely
average
> inflate
> > cheers
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
> > ADVERTISEMENT
Service.
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
-Adam Archibald
> -Adam Archibald
same
> time.
the
may
> haven't
my
> next
> > tires.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> > bridgestones.
> > "Josh Colombo"
> > <josh@surrealm To:
> > irage.com> cc:
> > Subject: RE:
> > 11:17
> > Please respond
> > to
> > BC-BFLegacyWor
> > ks
> cooler
> > as well.
> Those
> higher in
psi
> or
> > two.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> out.
in
definitely
average
> inflate
> > cheers
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
> > ADVERTISEMENT
Service.
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
I second that - don't the designation over there but in UK FK451 - a variant of the GRB is very good and pretty good value although for a few quid (bucks) more the Toyo Proxes are better.
Sent: Tuesday, July 23, 2002 5:37 PM
Subject: [BC-BFLegacyWorks] Re: Removing Intake "Snorkus" from Leagacy Turbo.
-Adam Archibald
> -Adam Archibald
same
> time.
the
may
> haven't
my
> next
> > tires.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> > bridgestones.
> > "Josh Colombo"
> > <josh@surrealm To:
> > irage.com> cc:
> > Subject: RE:
> > 11:17
> > Please respond
> > to
> > BC-BFLegacyWor
> > ks
> cooler
> > as well.
> Those
> higher in
psi
> or
> > two.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> out.
in
definitely
average
> inflate
> > cheers
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
> > ADVERTISEMENT
Service.
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
ADVERTISEMENT
-Adam Archibald
> -Adam Archibald
same
> time.
the
may
> haven't
my
> next
> > tires.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> > bridgestones.
> > "Josh Colombo"
> > <josh@surrealm To:
> > irage.com> cc:
> > Subject: RE:
> > 11:17
> > Please respond
> > to
> > BC-BFLegacyWor
> > ks
> cooler
> > as well.
> Those
> higher in
psi
> or
> > two.
> > Josh
> > Josh Colombo
> Leagacy
> > Turbo.
> out.
in
definitely
average
> inflate
> > cheers
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
> > ADVERTISEMENT
Service.
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
ADVERTISEMENT
Just another thing to think about Nokian Tyre produces
a Model called the NRZi, Their other models are used
in the states by some Rally/ice racers. I like the
NRZi on dry pavement, but they shine in the wet,
especially on front drivers.
> From: adamarchibald
> recomend the Falcon
> well for me.'
> -Adam Archibald
> > -Adam Archibald
> 4 tires at the
> same
> > time.
> so you do not fry
> the
> good and not very
> may
> > haven't
> my
> > next
> > > tires.
> > > Josh
> > > Josh Colombo
> > Leagacy
> > > Turbo.
> 4 will be ready to
> > > bridgestones.
> > > "Josh Colombo"
> > > <josh@surrealm To:
> > > irage.com> cc:
> Subject: RE:
> from
> > > 23/07/2002
> Leagacy Turbo.
> > > 11:17
> > > Please respond
> > > to
> > > BC-BFLegacyWor
> > > ks
> installing a tranny
> > cooler
> > > as well.
> > Those
> try runnin a tad
> > higher in
> alone, or drop a
> psi
> > or
> > > two.
> > > Josh
> > > Josh Colombo
> > Leagacy
> > > Turbo.
> > out.
> in
> shiftkit which
> definitely
> average
> previous owner). I
> > inflate
> about right.
> > > cheers
> > named
> > this
> it
=== message truncated ===
Do You Yahoo!?
> From: adamarchibald
> recomend the Falcon
> well for me.'
> -Adam Archibald
> > -Adam Archibald
> 4 tires at the
> same
> > time.
> so you do not fry
> the
> good and not very
> may
> > haven't
> my
> > next
> > > tires.
> > > Josh
> > > Josh Colombo
> > Leagacy
> > > Turbo.
> 4 will be ready to
> > > bridgestones.
> > > "Josh Colombo"
> > > <josh@surrealm To:
> > > irage.com> cc:
> Subject: RE:
> from
> > > 23/07/2002
> Leagacy Turbo.
> > > 11:17
> > > Please respond
> > > to
> > > BC-BFLegacyWor
> > > ks
> installing a tranny
> > cooler
> > > as well.
> > Those
> try runnin a tad
> > higher in
> alone, or drop a
> psi
> > or
> > > two.
> > > Josh
> > > Josh Colombo
> > Leagacy
> > > Turbo.
> > out.
> in
> shiftkit which
> definitely
> average
> previous owner). I
> > inflate
> about right.
> > > cheers
> > named
> > this
> it
Do You Yahoo!?
Yes, I placed mine inside the guard as well because in those pics where
they've cut the hole in the airbox is where the ABS unit sits on my car.
Also, where they've positioned the intake is way too low for my liking.
Even though the inner guard kind of protects it still, I was worried
about ingesting water and dirt so mine sits right up high inside the
guard. Depends how often you do river crossings I 'spose.
Nick (in Aust)
Douglas Hancock wrote:
> By the way I did'nt do mine like that I placed it in the guard. By the
> Turbo.
> everyone.
> From: Z1Auto@aol.com [mailto:Z1Auto@aol.com]
> Turbo.
> Impreza
> Yokohama A520
> Toyo Proxes T1S
> tc.,
> weight,
> work.
> most
> zZz
> <http://docs.yahoo.com/info/terms/>.
> zZz
> ADVERTISEMENT
> zZz
Nick (in Aust)
> Turbo.
> everyone.
> Turbo.
> Impreza
> Yokohama A520
> Toyo Proxes T1S
> tc.,
> weight,
> work.
> most
> zZz
> zZz
> ADVERTISEMENT
> zZz
I have done this mod about a year ago and it works well.
I removed the standard airbox and snorkel and then heated and molded
the pvc ducting so that it fits perfectly through the snorkel opening
into the engine bay. So it simply provides a nice flow of 'cold' air
onto my foam Pipercross pod filter. You will need to fab some sort of
heat shield aswell to protect the intake from engine heat.
Risk Free!
Risk Free!
No but maybe Rob from OZ does. I think that’s were I got them from.
Sent: Tuesday, 23 July 2002 10:42 PM
Doug,
Josh Colombo
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
Doug,
Josh Colombo
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
Mine suts about 3in above the front light and about 5in back from it sucking up the good stuff. I used 1 90degree bend and a 135degree bend. I fluted the end of the pipe using a heat gun and pushed it over the funel when it was soft. Sanded the end back until it was smooth. I have some pics and will have to get them in the photos section.
From: Nick Robinson [mailto:nkrobinson@picknowl.com.au]
Sent: Wednesday, 24 July 2002 10:15 AM
Nick (in Aust)
> Turbo.
> everyone.
> Turbo.
> Impreza
> Yokohama A520
> Toyo Proxes T1S
> tc.,
> weight,
> work.
> most
> zZz
> zZz
> ADVERTISEMENT
> zZz
ADVERTISEMENT
Nick (in Aust)
> Turbo.
> everyone.
> Turbo.
> Impreza
> Yokohama A520
> Toyo Proxes T1S
> tc.,
> weight,
> work.
> most
> zZz
> zZz
> ADVERTISEMENT
> zZz
ADVERTISEMENT
Yes, I would appreciate it if you did post your modified snorkus pics,
I'd like to get a grasp on the idea before I start chopping!
Thanks,
Mark
Thanks,
Mark
the magazine I got this from is gone.... somewhere, somehow it has gone missing.
The pictures were just a basic idea on what could be done and to show the resonator. I myself opted to open the std inlet in the air box and feed air through from the inner gaurd.... not as the picture does by cutting holes or having it pickup down low where water may enter.
cheers, Rod... in oz.
PS...sorry for late response... been skiing.
From: Douglas Hancock <mailto:douglashancock@optusnet.com.au>
Sent: Wednesday, July 24, 2002 5:31 PM
Doug,
Josh Colombo
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
Doug,
Josh Colombo
Yokohama A520
Toyo Proxes T1S
ADVERTISEMENT
