I second that - don't the designation over there but in UK FK451 - a variant of the GRB is very good and pretty good value although for a few quid (bucks) more the Toyo Proxes are better.
----- Original Message -----
adam@mymindseye.ca>
To:
BC-BFLegacyWorks@yahoogroups.com
Sent: Tuesday, July 23, 2002 5:37 PM
Subject: [BC-BFLegacyWorks] Re: Removing Intake "Snorkus" from Leagacy Turbo.
Correction "I would recomend Falcon tires, they are to expensive and
they work really well.". I ment to say 'I would recomend the Falcon
GBRs or the Ariez. They have both worked very well for me.'
-Adam Archibald
--- In BC-BFLegacyWorks@y..., "adamarchibald" <adam@m...> wrote:
> I would recomend Falcon tires, they are to expensive and they work
> really well. My 2 cents
> -Adam Archibald
> --- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> > Since you have AWD.....you need to replace all 4 tires at the
same
> time.
> > You need to keep the rolling diameter the same so you do not fry
the
> > center diff and transmission.
> > Kumho's, Ecsta 712 are supposed to be pretty good and not very
> > expensive. I've heard good things about them....have heard they
may
> > have small issues with being perfectly round.....not sure......I
> haven't
> > had any direct experience with them, but am considering them for
my
> next
> > tires.
> > Josh
> > Josh Colombo
> > Josh@s... <mailto:Josh@s...>
> > "Life, an ever-changing melody
> > of beats and rhythm" - ME
> > -----Original Message-----
> > From: paul.travers@v... [mailto:paul.travers@v...]
> > Sent: Monday, July 22, 2002 6:23 PM
> > To: BC-BFLegacyWorks@y...
> > Subject: RE: [BC-BFLegacyWorks] Removing Intake "Snorkus" from
> Leagacy
> > Turbo.
> > thanks again, and I agree they suck! 2 of the 4 will be ready to
> > replace in a few months, will go for some directional tyres, maybe
> > bridgestones.
> > "Josh Colombo"
> > <josh@surrealm To:
> > <BC-BFLegacyWorks@y...>
> > irage.com> cc:
> > Subject: RE:
> > 23/07/2002 Leagacy Turbo.
> > 11:17
> > Please respond
> > to
> > BC-BFLegacyWor
> > ks
> > I will let ya know how it goes. I'll also be installing a tranny
> cooler
> > as well.
> > I've never been a real fan of the dunlops.....they sucks....IMO.
> Those
> > are reasonable tire pressures......you could try runnin a tad
> higher in
> > the front....maybe 33-35, and leave the rears alone, or drop a
psi
> or
> > two.
> > Josh
> > Josh Colombo
> > Sent: Monday, July 22, 2002 5:20 PM
> Leagacy
> > Turbo.
> > thanks Josh. Will be interested to hear how your shift kit turns
> out.
> > My girlfriends dad owns not 1 but 2 (!!!) Dodge Challengers (rare
in
> > NZ), one is manual but the other auto with shiftkit which
definitely
> > does the job. My wheels are standard 205/60/R15. Tyres are
average
> > quality non-directional Dunlops (fitted by previous owner). I
> inflate
> > to 32/33 PSI which the tyre shop guy said was about right.
> > Adrian - snorkus project sounds like a plan
> > cheers
> > Have you seen our website?....
http://www.vodafone.co.nz
> > CAUTION: This correspondence is confidential and intended for the
> named
> > recipient(s) only. If you are not the named recipient and receive
> this
> > correspondence in error, you must not copy, distribute or take any
> > action in reliance on it and you should delete it from your
system
> and
> > notify the sender immediately. Thank you.
> > Unless otherwise stated, any views or opinions expressed are
solely
> > those of the author and do not represent those of Vodafone New
> Zealand
> > Limited.
> > Vodafone New Zealand Limited
> > 21 Pitt Street, Private Bag 92161, Auckland, 1020, New Zealand
> Telephone
> > + 64 9 357 5100 Facsimile + 64 9 377 0962
> > To unsubscribe from this group, please send an email to:
> > BC-BFLegacyWorks-unsubscribe@e...
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> > ADVERTISEMENT
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> named
> this
system
> and
solely
> Zealand
> > Limited.
> Telephone
zZz <
http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
http://rd.yahoo.com/M=228862.2128520.35 ... 6-1039-302>
zZz <
