Two MBC answer
Locked
Rabin Rutten-James
Two MBC answer
Post by Rabin Rutten-James »
Couple people wanted this so here goes:
Pictures would best show it, but both the car and the manuals are in
Calgary - 8 hours away!
A brief description is as follows:
I changed where the boost signal for the MBC was taken from - instead of the
turbo spigot, I tapped into a larger opening on the driver-side intake
manifold. It goes from there to the under hood MBC then to the wastegate.
(The boost guage is also tapped into the manifold directly)
>From the turbo spigot, it goes to a 0-15 psi pressure regulator set to only
release 8.5 - 9 psi, then to the solenoids. Two outputs from the solenoid -
one goes back to the intake pipe, the other goes to the wastegate. I tee'd
them together and ran them both to the intake before the turbo.
This can be a dangerous set up since the computer happily thinks it's within
spec and you can crank it as high as you want. BE VERY CAREFULL!!!!!
We ran VP race fuel, and we had boost set at about 14 psi (intentional spike
to 17 intitially). We are still having issues with the engine management,
so I am not sure if this is a recommended set up.
I personally would keep it set up the way we had before. I used our MBC to
prevent any boost the wastegate until 10 psi, it would then crack and the
cars solenoids would keep the boost right at 11 psi - all the overboost
protection was still effective. Nice and safe way to play.
I wish I could provide a picture as well, but without the car it would be
from memory only. Let me know if the description is not sufficient.
Rabin
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Tuesday, July 30, 2002 12:46 PM
Subject: [BC-BFLegacyWorks] Re: Old legacy rally car in TO show
> so where exactly do you put the mbc that "tricks" the ecu? i think i
> have an idea but i wouldn't want to do any damage and i trust you'd
> know better than i.
> --- In BC-BFLegacyWorks@y..., Rabin Rutten-James <rabinjames@s...>
> wrote:
> > The rally car you saw at the TO show is now the rally car we race!
> (DBR
> > Rallysport) They were very optimistic with that figure - maybe
> without the
> > restrictor it was possible.
> > We run a much better MBC, but the trick around the fuel cut off is
> to run
> > two MBC's. One for engine, one to "trick" the ECU into thinking it
> was only
> > hitting 10 psi. They were running straight C116 (Leaded race fuel)
> and
> > would routinely crank up the boost well past 17 psi.
> > We don't have the budget for engine rebuilds, or for running 100%
> race fuel,
> > so we are much easier on the boost - except for last race. With
> the 32 mm
> > restrictor, my slightly modified GL-10 Turbo wagon feels like it
> would spank
> > it.
> > Rabin
> > From: <FREDERICK.WHITMORE@C...>
> > To: <BC-BFLegacyWorks@y...>
> > Sent: Monday, July 29, 2002 1:18 PM
> > Subject: FW:[BC-BFLegacyWorks] Re: subaru 55
> > > They had the old Legacy Rally car at the 2001 Auto Show here in
> T.O. The
> > > stats on the car said it had 200 HP and the hood was open and it
> basically
> > > looked identical to my car. Thus, there was NO intercooler.
> I've been
> > > wondering ever since what was done to get that extra 40 HP. The
> subaru
> > guys
> > > that were by the car didn't know but told me that it is the same
> engine as
> > > mine.
> > > FREDDEX
> > > ------------------( Forwarded letter 1 follows )------------------
> > > Date: Mon, 29 Jul 2002 18:496 -0000
> > > To: BC-BFLegacyWorks@y...
> > > From: jgrahn555@h...
> > > Sender: sentto-2208544-9654-@gcs.alias
> > > Reply-To: BC-BFLegacyWorks@y...
> > > Subject: [BC-BFLegacyWorks] Re: subaru 555?
> > > 555 makes cigarettes. They were and still are one of subarus title
> > > sponsors.
> > > -Jason
> > > --- In BC-BFLegacyWorks@y..., "ob1poor" <ob1poor@y...> wrote:
> > > > ok couple questions, can anyone tell me what the 555 was for on
> > > the
> > > > older subaru rally cars? and also remember back in '93 when
> subaru
> > > > had collin mcrae driving a legacy in the wrc? well what all did
> > > they
> > > > have to do to that car to prepare it for a rally? just
> wondering
> > > if
> > > > it was "rally ready" from the factory as the new wrx are. well
> not
> > > > completely "rally ready" but i'm talking for the most part,
> engine
> > > > wise and what not.
> > > To unsubscribe from this group, please send an email to:
> > > BC-BFLegacyWorks-unsubscribe@e...
> > > Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> BC-BFLegacyWorks-unsubscribe@egroups.com
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/7dY7FD/R_ZEAA ... /XoTolB/TM
Locked
