so i just got a liberty air-water ic and pump, all i need is the reservoir and radiator. Whats the best kind of radiator to use? i want one that is fairly large, as from what i have read this is important.
Thanks, Teague
air-water radiator recomendations
'99 Impreza L 2.2 powa!
"If at first you don't succeed, failure may be your style."
This was talked about before, but the best bet is a Goldwing radiator. I got mine off of e-bay for something like $22. It flows like a mother and was cheap and has the ability to cool an entire 1200cc engine. Some small modification and it should fit in the front end just fine. But, I have yet to install my radiator.
