will a wrx front strut bar fit
legacy32656
Post by legacy32656 »
will a 02-03 bar fit my 90 or my 93 legacy????
can i make it fit?? or can i get one for like 30 bucks new??
thanks brian
don't think so.
legacy32656
hot even close???is are car wider or is that one???
mTk
no title
Post by mTk »
I'm not sure what the difference is, but you can also get one for any GC8 impreza and it should fit fine.
MK
1992 BC672 AWD 5MT
legacy32656
whats a gc8 impreza??? how much do they run???
91White-T
Post by 91White-T »
I belive GC8 is 93-01 Impreza. I've seen em as cheap as 20 bucks, but you may want to go with something a little better quality...
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
strut bar.....I thought you said sway bar....my bad.
strut bar....still not sure. As mentioned the 93-01 impreza strut bars should work fine in the front.
gordini
Post by gordini »
i just installed strut bar designed for a rex on my 91 ss and it fit fine after bending the mounts a bit. i believe the bolts are placed in a slightly different manner on the newer cars, but it is very easily rectified. good luck bro.
Fernely
Post by Fernely »
GC8 strut bars will work. You can also use the rear strut bar from cusco.
We have two seasons in Miami, Hot and Hotter!
legacy32656
does that mean a wrx????
thanks again for the advice.
brian
