What fuse can I safely use to tap into so I can install fog lights on a
91 sport sedan and have them turn off with the car so I don't leave them
on?
Also how do the 92+ fog lights work? My turn signals are in the bottom
of the bumper where I want my fogs to go. Is it easy to make the front
side marker lights into turn signals? Any tips?
Fog Light install
illanrob_
Fog Light install
I installed fog lights on my 93 Legacy L. I used a relay, any 15A
will do fine, mounted at the battery hold down bolt/nut. I ran the
relay coil to the ignition can't remenber which wire, but the 12V
goes off when the key is removed. The relay contacts one to the
battery, which is allready neerby, the other to the fog lamps.
Everything still working 8 years later.
Robert Illan
Robert Illan
