My right headlight washer was broken when I got the car. I've sourced a used replacement.
Does anyone know exactly what bonds the unit to the bumper (fender)?
Headlight washers
Headlight washers
- Rob
1992 Legacy Turbo Estate (Wagon) / 5MT / 186k miles. [url]http://www.griggs-taylor.co.uk/legacy.html[/url]
1986 Suzuki GSX-R400 / 6MT / 43k km. [url]http://www.griggs-taylor.co.uk/mybike.html[/url]
ericS2the6
eastbaysubaru
I have wondered about this...I'd seen them, but couldn't figure it out since we didn't have them. Are there aftermarket headlight washers we could put on or jury rig something? Any ideas? Do the stock headlight squirters just come on when you wash your window, or do they have their own button and such?
much thanks
Micum
much thanks
Micum
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
They have their own separate button in the same panel as the front fog light switch (it may be a blank in the US cars). It's actually the only car I've ever seen with a separate switch for headlight washers...
- Rob
scottzg
headlight washers would be a peice of cake to design- its basically the same system as the windshield washer system. You could tap your wiper fluid reservoir, salvage the little washer pump, hoses and nozzles from a usdm car, run wiring from a hot wire under dash to a button on the dash (make your own, or do whatever) back to the pump, and run the hoses out under the bumper and glue (epoxy) on the windshield washers. If there is too much water flowing, put a resistor on the pump. I think too much power would be cool though
That said, it sounds like a miserable job for a stupid feature. you gotta run wiring all over the place, take out your radio, install switches, run hose everywhere, and take apart your front bumper. And then its only one more thing to break.
Im interested if anyone does it though.
ericS2the6
The headlamp squirter mod has been on my list since day one. I have done a bit of homework since then as well.
Here is a link to all the info you need (part numbers etc). Although it is for the GC8 impreza, everything will work for the first gen legacys. However the nozzle has a slightly different bottom lip on it, although im sure they will still work, and the button is different than for the legacy.
http://www.scoobymods.com/forums/showth ... hreadid=61
I think if anyone could source a part number for our button, i would defintetly do this
eastbaysubaru
