will goodridge s.s. brake lines meant for a 02wrx fit my 92 legacy turbo?
the part # for the lines i bought is A24215A. i paid $99. please help.
thanks
-aaron.
Should fit.....the only thing you'll probably find that is different is how they attach to the caliper. I believe the WRX uses a clamp type setup to attach the lines to strut, while the older ones use a pass through.
IMO the clamp is better.....less of a pain in the butt.
They fit, legacy777 is right. The wrx lines use a sliding BOLT attachment. I personally just used a zip tie to attach this to the previous strut mounting spot.
