I have a 92 ej22t and im having problems/issues with my 3rd fuel
injector. I was wondering if there were any better aftermarket
injectors or if any injectors from any of the other engines would
work the same or better because a new one from the store is 100 bucks
and if im gonna replace one i wanna replace them all with better
ones. any advice?
-thanx
-Jason
92 ej22t fuel injector problems
roderic@cableone.net
Jason-Contact Wayne @ www.rceng.com and pose your questions to an expert. Are you using factory injectors or some whiz-bang replacement recommended by the parts store? I had 170k on stock ones with no problems. Good luck-Rod (BTW, I`ll be off line for another 2 mos until I can get the rest of my stuff moved back to Calif. I`ll update everyone then on the new motor.)
