Kartboy shifter bushings and exhaust hangers
Got a new part? Is it the best thing you've ever seen? Is it a complete ripoff? Let us know about your parts and service.
HomeSlice
Post by HomeSlice »
i love them. really settled down my exhaust. the shifter you will also notice the diffrence. very stiff. but then again i put all new subaru bushings on my shifter when i did the diy short throw...... great cheap mods to think of.
Cheers,
jim
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
FrmRgz2Rchz
Post by FrmRgz2Rchz »
Did you use the bushings meant for the WRX?
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
HomeSlice
Post by HomeSlice »
yup-- i noticed ebay sells energy susp ones for 9.99 not bad. but the kartboy is two bushings when the energy susp is one.
ciper
Post by ciper »
I can understand shift bushings.
Why do you care, or why do exhaust hangers matter?
HomeSlice
Post by HomeSlice »
well ciper you understand how flexable stock bushings are! this is not only a upgrade but also replaces your 12 year old bushing and muffler hangers. if you mess with custom exhaust it aint always to oem spec--larger pipes less restristion causeing it to shake around durring high rpms.
this makes the exhaust stay still dude!
ciper
Post by ciper »
But why do you want it to stay still? Id think you would rather it move along with the engine so that joints dont get stressed.
Brat4by4
Stratified
Post by Brat4by4 »
Exhaust moves mostly with body motion. If they are too stretchy they will be the cause of stress when it lets the exhaust move too much. We are talking about near the rear, not right by the engine.
ciper
Post by ciper »
That makes sense, I guess the muffler and resonator is heavy enough to be effected by inertia more than the changes in position from the engine.
BTW doesnt it seem odd to bolt the exhaust right to the transmission? I think it would transfer alot of heat
HomeSlice
Post by HomeSlice »
its only the back 4 hangers---no where close to the motor where the flex will be flexing---i dont know why subaru bolted the exhaust to the tranny... but its not directly or close or anything. goes thru a couple of cool brackets first. so should be fine.
Post by entirelyturbo »
I need to get new exhaust hangars for my car. I can grab my muffler and shake it until it starts hitting something without any effort at all. In fact, that's probably the strange noise I've had for a while after going over a bump...
HomeSlice, where did you get these bushings?
*Formerly DerFahrer*
HomeSlice
Post by HomeSlice »
nabisco- guy named luke-- right here -----> http://forums.nasioc.com/forums/showthr ... did=466084
