Hazard button bulb info needed?
I tore the dash apart today to try and fix the hvac controls from intermittantly not working. I think I might have fixed the controls. I cleaned the connector with electrical cleaner, put some di-electric grease on there because the problem seemed worse when I used the a/c. We'll see how it works.
anyway, I also pulled the hazard button out, and want to replace the bulb in there. Anyone know the bulb type. I'm assuming i can get it at radio shack.
It's a radioshack bulb, pn 7219.
it was there in stock when I got mine.
Did you ask one of the sales people?
hmm....looks like they either changed the part # or stopped carrying that bulb. It's just a little christmas tree "style" bulb with wires on the end.
this is the closet thing I could find when I searched for bulb
http://www.radioshack.com/product.asp?c ... d=272-1092
I don't know if the lamps I posted will work. They're the only ones on the site I found that "look" similar.
No soldering is required. Take the hazard button out, take the bulb out, take it to radio shack and say you want a bulb similar to that.
Cool,
glad they still carry them
