1994 Turbo Wagon [Auto]
bignose
Post by bignose »
Hi,
The ole car has 443000km's on it. I know the fluid in the tranny/diff's is likly getting pretty tired.
I want to replace said fluids, any adivce as to what brands I should use, issues to look out for, gotcha's etc. ?
I'm leaning towards mobil 1, only because a relative can get me good prices.
THanks.
http://www.bignose.ca/legacy/pics/
ciper
Post by ciper »
For around 80$ you can get the system "flushed" with about 20 quarts of fluid using a very simply machine at jiffy lube. Imagine a long pipe with a hockey puck inside seperating the top from the bottom. Above the puck is 20 quarts of fluid and this end of the pipe is connected to the input. Below the puck is where the old fluid fills up. As the vehicle runs it constatly dilutes the old fluid until nearly all the old fluid has been removed.
HomeSlice
Post by HomeSlice »
good lord thats alot of k's
listen to ciper- trany flush is great. i usta have a wyns one like that at my old job
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
MY92
Post by MY92 »
Ciper: can you do that at home yourself?
John
http://www.cardomain.com/ride/560635
QuickDrive
Lurker-King
Re: 1994 Turbo Wagon [Auto]
Post by QuickDrive »
bignose wrote:Hi,
THanks.
That gives me hope knowing you live in the same Climate as me.
I say if you haven't done it inawhile then go for it.
Wow, another 50k and you'll be at the 1/2 million mark.
R I P-------- 91 Turbo 4EAT --------R I P
What would happen if you were to disconnect the hose from the outlet of the ATF cooler and stick it into a bucket of fresh ATF, and connect another hose from the cooler outlet into a waste bucket? Would you be able to flush out the old fluid that way if you ran it for a little while in each of the gear ranges?
people have talked about that, and it is feasible.....I just think it's a little risky and most likely quite messy
I hate atf
