When I got the car, it had terrible clutch shudder when taking off
from a standing start or when reversing. Time for a clutch methinks --
having never driven subarooos before.
I figured I might as well adjust the free play at least before committing to
a big job. After waiting over a month for a CD manual from ebay
(another story) I got the free-play numbers: 3mm - 9mm, but the
dang manual doesn't say where on the release lever to measure that!
Anyway, the cable was set up with 0mm free play by any measure, obviously not good.
So I set it up to measure 10mm at the outer end of the lever. Now
the clutch is MUCH better but still shudders a bit; quite a bit sometimes.
Here is my question (finally!) Am I on the right track here? Is there a magic
free-play number that puts the cam on the pedal in sync with the clutch?
If so, what is that number?? and where should I measure it? Failing that
I'll just experiment, but it would be helpful to hear if anyone else made
significant progress fixing the shudder this way.
Or maybe I DO need a new clutch.
Chris
PS: I did a site search on this. There seems to be some info around on
this problem for newer legacys, with hydraulic clutches, and one
link to a TSB which is broken.
