Need some clarification please!
Opie
Post by Opie »
I have access to an entire WRX exhaust (Header, down-pipe, mid-pipe & axle back) will this all fit on the EJ22t? I plan on using the stock EJ22t up-pipe since it doesn't have a cat!
Also have a set of '99 Impreza RS springs and struts to pick up! :D
2000 Legacy B4 RSK, 2013 BRZ-Track car, 2021 Forester Sport
legacy92ej22t
Post by legacy92ej22t »
It will take a little work but yes. The DP should bolt right up but from there back you'll probably have to redo the exhaust hangers and add a few inches of pipe to the axle back portion. The WRX has it's O2 sensor in a different location also, so you'll either have to put a bung in the dp and cap the stock one or lengthen your O2 wire.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
91White-T
Post by 91White-T »
The stock WRX header also has a cat somewhere I believe...
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
LegacyT
Post by LegacyT »
Nope, just upipe, downpipe and midpipe. the WRX has 3 we have 2.
Mark,
yeah...you'll need to do something similar to this for the axle back piece.
http://bbs.legacycentral.org/viewtopic.php?t=640
