Maybe a problem? can u guys help!?
Hey this problem only started occuring last night.. i was out with the girl and we stopped for like 20 mins at a friends house we were talkin to him outside and i had my headlights off and the car on idle.. well after the 20 mins or so i went to leave and turn around and the car stalled out check engine light blah blah.. but then i stoped the car put it in park(automatic) and tryed starting her up again it was hestitating for like 2 seconds but then started up fine and i drove it the rest of the nite! but then also i stopped somewhere else like hour later and i could tell it was about to stalled when i pulled away slowly but then jus hit the gas a biut heavier and it was fine... PLEASE HELP.. thanks guys
Pull the code for the check engine light. That'll give you a hint.
http://www.surrealmirage.com/subaru/engine.html
Sounds like the same crap I just went through. Check your iac valve and see how it is. Also pull codes as it coul be something else
