Dizzy
Post
by Dizzy »
Gang -
Does anyone know where this is? I can't find it in the manual. The wiring diagram shows a relay as part of the circuit.
I'm seeing the following behavior with the rear wiper that leads me to believe it's the relay:
* Set stalk switch to 'on' position (rear wiper doesn't move)
* wait a couple minutes with switch in 'on' position, car running
* wiper starts working
The above behavior leads me to believe it's neither the switch nor the wiper motor. TIA.
2004 STi
1993 Touring Wagon
Post
by vrg3 »
It could actually be the wiper motor... not likely the switch. But it makes sense to check the relay...
The info I have says it's "Behind right rear quarter panel, near wheel well."
Dizzy
Post
by Dizzy »
Cool. Thanks for the heads up. Actually, I was hoping it was the motor. They seem pretty easy to swap. I dislike electrical gremlins.
2004 STi
1993 Touring Wagon
HomeSlice
Post
by HomeSlice »
u getting power back there?
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
Dizzy
Post
by Dizzy »
Yep. The wiper fluid jet works & all lighting is OK.
2004 STi
1993 Touring Wagon
HomeSlice
Post
by HomeSlice »
Dizzy wrote:Yep. The wiper fluid jet works & all lighting is OK.
i think the jet may work on a differant fuse.
Dizzy
Post
by Dizzy »
I replaced the battery & I no longer have this problem.
2004 STi
1993 Touring Wagon
