Headlights flicker?
91White-T
Headlights flicker?
Post by 91White-T »
My headlights flicker off sometimes and I have no clue why, the connectors seem to be in good shape, and all the relays are there. Any ideas?
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
THAWA
Post by THAWA »
wires maybe? or ground? does it happen at any particular time?
HomeSlice
Post by HomeSlice »
are you at idle when it happens?
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
What do you mean by flickering off? Does it flicker rapidly for a second or two, or does it turn off completely? Do they flicker on and off or do they get bright and dim? Do both bulbs do it at the same time?
It could be anything in the circuit path... Fuses, relays, switches, bulbs... Some clues can help us figure it out.
91White-T
Post by 91White-T »
They both turn off completely for a fraction of a second, and not usually at idle, mostly when I'm driving.
HomeSlice
Post by HomeSlice »
hmmm sounds like your shorting somewhere--do your parking lights go off too>?
Brat4by4
Stratified
Post by Brat4by4 »
that would be sort of hard to see while you are driving...
HomeSlice
Post by HomeSlice »
Brat4by4 wrote:that would be sort of hard to see while you are driving...
well how bout your interior lights dude :lol:
scottzg
Post by scottzg »
does it happen when you touch the brakes at speed? if so, charge up your battery
georryan
Post by georryan »
When I hit my brakes after a while my radio lights dim and come back. I've heard that is common and is either a sign of charging up the batter to fix it or a ground problem.
The other thing I've heard could be a sign is when your heater fan/ac fan comes on it can cause things to flicker. Does it happen at any of those times?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
ciper
Post by ciper »
How about the relays?
91White-T
Post by 91White-T »
The headlights are the only thing that flicker, and as far as I can tell it's not related to anything else (braking etc.)
Re: Headlights flicker?
Bringing this thread back from the dead. My headlights started flickering and turning off completely for a second and coming back on. I thought maybe it was related to my stereo at first because I had it cranked (no amps, just stereo running stock front speakers) so I turned it off and it's been off for a couple days and it still does it. Tonight was when it did it the worst when it actually turned completely off for a solid second and came back on.
Could this be a relay going out? I don't like my lights going out in the dark.
I'd say it's either a relay or a ground.....or possibly could be the lighting switch stalk.
I read that people have had this problem with the contacts being dirty in the stalk but I wiggle it around a lot and it doesn't cut out. I'll find that relay and swap it out.
