BOV questions.
BOV questions.
I have a stock wrx BOV and a stock WRX intercooler. What I was wondering is, what does the peice on the side of the BOV connect to. It has 2 screws in it like it is to be bolted to a fitting. But Im not sure what. Any help is appreciated. Oh, and maybe some pics. Thanks
- quasi-mod-o
![Image](http://www.incorrigiblegeek.com/images/subarushots009.jpg)
Here's a pic of the engine bay of my GF's '04 WRX. The WRX uses a recirculating diversion BOV like our stock BOV. People have struggle with what do do with it when making a WRX IC work. If you leave it open it create air/fuel mix issues because it confuses the system. There are a few threads in this forum where folks talk about the issue as well as possible solutions. My plan is to make custom tubing that runs back to the stock location dumping it back into the intake before the turbo...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
There is a 90 recirculation piece that bolts to the hole you're referring too, if it was on the BOV it would bump into the throttle cables on the intake manifold if you used it with the WRX IC, unless you just leave it open air.
Matt: are you going to try to use a WRX BOV/WRX IC combo? cause there is like a quarter of an inch of workable space between the WRX BOV and the throttle cables, which is right where the BOV points without that 90 degree piece.
:twisted::cool::twisted: "Plenty of time, to ruin my life, so why start now?" The Movie Life
1993 Sports Sedan, Exhaust, MBC, 02 WRX IC, KYB GR-2s...Now with old back seat!
