Changing the valve cover gaskets
Rish
Post by Rish »
I took an appointment for Friday at my local 'roo dealer to get the above done. The quote was $143 cdn plus taxes. ($89 in labour, and $26 each :shock: for the gaskets). Any thoughts on the cost? I can honestly say that I do not have the time (daily driver) or the indoor workspace (winter) to do it myself, and with the current cold, they have started leaking rather badly.
Rish
ciper
Post by ciper »
Too expensive. From www.subaruparts.com they are 14 canadian, and thats not always the cheapest place!
The job is pretty easy and takes very little time. I suggest doing it yourself. Why do you need indoor space? The replacement of the right side consists of three bolts. The replacement of the left is three + two for the oil filler neck.
Post by entirelyturbo »
If you don't wanna clean up the covers, since they're obviously covered in oil, it should be about a hour job tops. You'll need to remove the battery and windshield washer reservoir on the left, and maybe the air box on the right. Past that, it's a cinch. Just remember to get new grommets as well as gaskets, chances are your grommets are leaking too.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
legacy92ej22t
Post by legacy92ej22t »
I too will be tackeling this job soon. Seems like it will be a snap. =)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
scottzg
Post by scottzg »
me too! one is leaking torrentially onto my subframe, and it stinks if i drive on the freeway, then stop at a light. Very annoying.
As other's have mentioned, make sure you replace the grommets and the O-ring on the oil filler neck.
More then likely the grommets & oil filler neck are what's leaking. You should be able to get at the valve covers from underneith the car easier, so you shouldn't have to remove the battery or any of that crap.
ciper
Post by ciper »
subyluvr2212: I removed NOTHING except the valve covers themselves when I did mine. I did it in a JC Penney parking lot in about 25 minutes and I even sprayed them down in carb cleaner.
Yeah, shoulda said "it would be easier..." It certainly is possible, might end up with a few more skinned knuckles, but it's doable...
However, I did learn that Legacies are much easier to do than EA82's. My XT was MUCH harder :roll:
Rish
Post by Rish »
Thanks for the help and advice :)
Rish
kingston
Post by kingston »
was anybody elses driver side cover tightly squeezed to the frame of the car....cant wedge it out
douglas vincent
Post by douglas vincent »
Its a pain in the ass.
Personally, if you have the $143 Canadian, I would do it, but only if you can get a written warrenty against leaks.....
Splinter
Post by Splinter »
HUGE HELPER!!!
Unbolt the engine mounts and jack up the engine by the oil pan (use a piece of 2x4 so you dont dent the pan). 2-3 inches should be enough.
Makes the job 900x easier.
Bheinen74
Post by Bheinen74 »
my advice for people who think they have valve covers leaking, is to simply replace the grommets first. Then after driving the car for a week or so, the leaks will most likely be gone.
if.....they are still leaking, then replace the cover gaskets.
But most ALL times, the leaks are at the grommets.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
kingston
Post by kingston »
got it figured out...it's like tetris! had to take the oil spout off first.
07Evolved
Post by 07Evolved »
I need to do this now...does anyone have a write-up on this? I couldn't find one.
Does anyone have the part numbers for the gaskets, grommets, o-ring on the oil filler neck, etc so I know I have exactly what I need?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
It's pretty straight forward. Remove three bolts, replace the gasket & grommets and that's it.
07Evolved
Post by 07Evolved »
Thanks Josh...
Any chance you know the part numbers? How about the o-ring...replace that as well?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
Not off the top of my head. But you can d/l the parts manual from me, which has all the part #'s in it.
http://bbs.legacycentral.org/viewtopic.php?t=30531
Apex3
Post by Apex3 »
Is there a bolt pattern for it? I mean i know it's only 3, but it could still matter...I just remember on my e30 there was a specific patter, there were about 12 bolts though.
Lunatech
Post by Lunatech »
Start in the center and work outward.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
07Evolved
Post by 07Evolved »
Legacy777 wrote:Not off the top of my head. But you can d/l the parts manual from me, which has all the part #'s in it.
Thanks again Josh!
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
