Look good on a black 93 sport sedan?
J-MoNeY
Post by J-MoNeY »
http://www.tirerack.com/upgrade_garage/ ... toModClar=
205/45-17 tires. The question is will they rub?
If the link doesnt work, go to tirerack.com and then put in the infor for a 93 Sport Sedan and look at the Sport Edition Fox 2 Sport. They are grey and will be going on a black car.
98 LGT
ciper
Post by ciper »
Sport edition fox two are VERY heavy wheels....
Edit your post title to something like "Have you seen Sport Edition Fox 2 on a legacy" or similar. I think one of the board member has them.
Post by entirelyturbo »
No they will not rub. My Rota Battle wheels were wider than that, no problems. The tire size you chose should be about the same diameter as stock wheels and tires...
I can see exactly where you're coming from, as I too really like those wheels. They're very attractive looking, functional and reserved, yet very sporty looking. However, ciper is probably right. They're probably pretty porky. And I can tell you from experience: a fat, porky set of rims/tires will REALLY slow you down :(
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
