Did anyone notice?
DLC
Did anyone notice?
Post by DLC »
Well, we're on the new server now. Downtime was a few hours, but not nearly as bad as i thought it might be. The big deal was that we didn't have to change nameserver info this time, which made the change almost instant.
The new box isn't much of a step up from the old one, in terms of hardware, but it's still nice. We're running a pair of 1GHz P3s on an ASUS CUV4X-D with 768MB SDRAM, a couple of fast IDE drives and Slackware in a Chenbro 2U case at the new colocation. It should prove to be a much nicer, and hopefully faster and more reliable solution.
Legacy Central
legacy92ej22t
Post by legacy92ej22t »
:D Schweet, Thanks Dave!
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Re: Did anyone notice?
Post by entirelyturbo »
DLC wrote:We're running a pair of 1GHz P3s on an ASUS CUV4X-D with 768MB SDRAM, a couple of fast IDE drives and Slackware in a Chenbro 2U case at the new colocation.
Those aren't that good, I have one of those sitting in my closet :lol:
Whatever it is, thanks a bazillion Dave! :mrgreen: Would any monetary donations from us rabid post-whores benefit the cause? :D
*Formerly DerFahrer*
DLC
Post by DLC »
It doesn't take a lot of horsepower to run a webserver, really, and we run a good amount of stuff on this box. Most of the time it just sits, probably bored with the lack of real stuff to do :D
Again, i appreciate the offer of donations, but for the time being we don't believe it will be necessary. If the situation changes i'll let the board know.
Legacy Central
Dave,
One thing I've noticed is that the board sometimes hangs while posting. I've noticed there has been more double posts, which would probably indicate others are having the same issues.
ciper
Post by ciper »
Yes, and ALOT of time outs
Something like error executing command, time exceeded 30 seconds.
Also some blank pages, you submit then get a solid white page.
ciper wrote:Also some blank pages, you submit then get a solid white page.
yeah....that's the hanging I have been getting.
HomeSlice
Post by HomeSlice »
ciper wrote: Also some blank pages, you submit then get a solid white page.
ditto
otherwise no probs. thanks dave
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
This "blank page" business JUST happened on my last post :cry:
But not on this post... :?
eastbaysubaru
Post by eastbaysubaru »
Yup, I too have the blank page syndrome:( after clicking submit.
-Brian
'04 PSM FXT
DLC
Post by DLC »
This should be fixed guys, thanks for bringing it to my attention.
Legacy Central
Out of curiosity, what was the suspected cause?
DLC
Post by DLC »
The new setup had an issue with the default email-notification parameters, more specifically, it wasn't working. For some reason, people like to be informed by email when there's a new post in a thread, which is bizarre :P
Those people having the problem were most likely in this small and odd club, and setting it up properly vanquished the dreaded blank screen.
Legacy Central
DLC wrote:The new setup had an issue with the default email-notification parameters, more specifically, it wasn't working. For some reason, people like to be informed by email when there's a new post in a thread, which is bizarre :P
Hehe... I used to do that until I started getting twice as much mail from the BBS as all other places combined. :)
Hmm... That's not the case. I got the blank screen a couple times, and I didn't have email notification turned on.
But it is possible that the email notification stuff was still responsible, since every thread subscriber gets an email whenever a post is made.
DLC
Post by DLC »
The latter is probably what was causing the blank screens for people not chosing the email notification. At the time the message is submitted, it probably handles that task, and the process was timing out.
Anyways, it's fixed, back to normality :D
Legacy Central
ciper
Post by ciper »
The strange thing is you fixed it and I had the problem yet I wasnt signed up for email notification.
Either way THANKS!
