ECU errors 15, 16, 22
cdanders
Post by cdanders »
I am assuming the 15 and 16 (fuel injectors 2 and 3 inoperative ) are causing the 22 (knock sensor).
Does anyone think Sea Foam might solve the issue? I have never used it.
Thanks,
93 Touring Wagon 116000m
I call her Suzy.
JasonGrahn
Post by JasonGrahn »
before trying to use that seafoam, make sure the injectors are connected correctly. Maybe pull off the connector and clean it up a bit. That would be the first thing that i do.
-Jason Grahn
After verifying the connectors, clear the codes and see if they don't clear, or if they come back right away.
123c
Post by 123c »
I have code 17 and 22, as well as many others the last time I pulled my codes. I wonder if I try this if it will help fix some of my problems...
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
yeah, it's worth a shot...clear them and see what comes back.
123c
oppps...
Post by 123c »
I pulled one of the connecter off of one of the injectors and the little notch that holds it in place broke off, and I was very careful when I was pulling it off. Is there a way to fix this, and am I ok. I was thinking that I can maybe slip an O-ring in there and use this to keep it tight. I am also waiting a while before I pull the other connectors off.
1989 Honda Elite 50
[/color][/b]
For some reason both of my passenger side injectors are like that -- the little tab that clips onto the harness connector is missing. They seem to hold in place decently anyway; I've put nearly 20,000 miles on the car since without troubles.
It might help to use a hair dryer or even a heat gun to make sure the plastic is warm before trying to remove the other connectors, to get maximum pliability.
123c
Post by 123c »
vrg3 wrote:For some reason both of my passenger side injectors are like that -- the little tab that clips onto the harness connector is missing. They seem to hold in place decently anyway; I've put nearly 20,000 miles on the car since without troubles.
I might try doing it when it's a little warmer too, and I will try the heat gun as well. I will just keep my eye on the connector and make sure it doesn't come loose...
1989 Honda Elite 50
[/color][/b]
the plastic just gets brittle. Mine did this on one of the older ones. Ran it for a long time....no prob.
