electric questions?
runnyD
electric questions?
Post by runnyD »
My cold starts are still a problem, so I bought a multi-meter. I would like to test the coils and fuel injectors. Could anyone give me a run down on exactly what I need to do.
THAWA
Post by THAWA »
coil Check out josh's site for the injectors, I think I've seen it there before but couldn't find them this time. Have you pulled codes to see whats stored? You're gunna want to reset the ecu after you do and see if the codes return, since the ecu doesn't remove the codes itself once the problem is fixed.
