electric questions?
Posted: Sun Dec 28, 2003 5:54 am
by runnyD
My cold starts are still a problem, so I bought a multi-meter. I would like to test the coils and fuel injectors. Could anyone give me a run down on exactly what I need to do.
Posted: Sun Dec 28, 2003 7:35 am
by THAWA
coil Check out
josh's site for the injectors, I think I've seen it there before but couldn't find them this time. Have you pulled
codes to see whats stored? You're gunna want to
reset the ecu after you do and see if the codes return, since the ecu doesn't remove the codes itself once the problem is fixed.
Posted: Sun Dec 28, 2003 8:51 pm
