Crank Pully Loose
Crank Pully Loose
My crank pully is loose and would like to know the simple way to tighten. Remove starterto get to flywheel-radiator-or vise gripes on pully. Thanks Dave in Tahoe
I use a strap wrench braced against another pulley and a big ass wrench.
Oh... okay, so putting it in gear won't do. On autos I think there's a little access port near where the transmission and engine mate where you can see the teeth that mesh with the starter. You can jam something in there to lock the engine in place.
Auto guys, help clarify this... :)
As for the torque spec, I believe the manuals do say around 100 ft-lbs, but some people will say to tighten it more than that because they have had problems with the bolt backing out. You may want to put some Loctite on the threads to be safe.
here's the access port
http://www.main.experiencetherave.com:8 ... P_2486.JPG
http://www.main.experiencetherave.com:8 ... P_2487.JPG
http://www.main.experiencetherave.com:8 ... P_2488.JPG
What you see is the flex plate. Stick a big screwdriver or breaker bar in there to keep the engine from moving.
I would also recommend you take the pulley off to check it out, as well as the crank & key.
When you put it back on, torque to 110-130 ft/lbs and wouldn't hurt to use some light lock tite on it.
- quasi-mod-o
LOL!!!vrg3 wrote:Eww, an ass wrench??
Find the access port as Josh linked pics to, then put something in between the flex plate and torque convertor, and then up against one of the bolts that hold them together. This is virtually foolproof. I'd be worried of something slipping off a flywheel tooth...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Another car, soon to be announced
that's why I took all those pictures when I had the intake off, much easier to pin point specific sensors or doo-dads.
