external ATF filter
91White-T
external ATF filter
Post by 91White-T »
Is this located on the driver side front wheel well? I see something there but can't quite tell what it is. How much does one go for? I'm assuming it's dealer only...
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
ciper
Post by ciper »
Its a retrofit. Not all cars have it.
The filter alone is 3X the cost of the kit which includes the filter.
THAWA
Post by THAWA »
it looks like a fuel filter, right between the cyl head and the battery/washerfluid area, though a little lower. IF you follow the oil cooler lines from the radiator you should run right into it if you have it.
ciper
Post by ciper »
Checked with 1stsubaruparts and the entire kit is less than 10$
mTk
no title
Post by mTk »
Got the kit for $11 from my dealer.
MK
1992 BC672 AWD 5MT
91White-T
Post by 91White-T »
Hm... It looks like I do have one in there but its leaking like crazy. Thanks for the info guys.
MY92
Post by MY92 »
I don't know if I have enough room for an external atf filter.
What do you lot think?
My car is JDM so factory w-a i/c (which are the fat hoses with the arrows on them).
John
http://www.cardomain.com/ride/560635
ciper
Post by ciper »
Someone want to give me access to a large amount of storage? I downloaded most of the files from techinfo.subaru.com and one of them happens to be the ATF filter kit instructions!
THAWA
Post by THAWA »
how much is large?
ciper
Post by ciper »
Id guess 40 megs?
THAWA
Post by THAWA »
if noone else does in about a week or so I can. assuming this hosting plan goes through
ciper
Post by ciper »
I cant give an accurate number because I didnt finish downloading yet and the site isnt accessable for some reason.
I'll set ya up ftp access ciper....feel free to upload until your hearts content.
i've been wanting to do the same thing, and suck down as much as I can for all years of the legacy and impreza lines.
ciper
Post by ciper »
Cool. For some reason my session keeps getting timed out so its taking longer than it should to get all the different files downloaded.
On my server or the techinfo.subaru site?
Did you get my email with the addy/logon info?
ciper
Post by ciper »
I got it and they are uploaded. I was having trouble with the techinfo site. For some reason my browser would get corrupt and I wasnt able to browse any longer. I would have to close all explorer windows to get it working again.
Do you need help to rename the files? They came from techinfo with the bulletin number instead of a name.
If they're all tsb's what I could is make an index of some sort that gives info on what the TSB is about. If there's other files besides TSB's, it'd be nice to have things separated. I haven't had much time to look at them, so not sure what's all there.
