Aluminum lower control arms?
Posted: Wed Jan 21, 2004 10:16 pm
by carfreak85
Did a search, and got frustreted with all the non realated posts. So Ill pose my question here! Do the aluminum lower control arms for a impreza sedan fit the legacy?
Posted: Wed Jan 21, 2004 10:30 pm
by JasonGrahn
yes. Done.
Posted: Wed Jan 21, 2004 11:04 pm
by THAWA
not any impreza only the gc chassis suspension parts fit. gc being 93-01. Most all the suspension parts are interchangeable since they use our chassis. My question though is do the gf and gm use the same chassis aswell?
ok
Posted: Wed Jan 21, 2004 11:36 pm
by carfreak85
so john, you have them on your car? what is involved in installing them? are they bolt in or what?
Posted: Thu Jan 22, 2004 12:30 am
by evolutionmovement
I have a set waiting to be installed from a GC Impreza. Going under the car they match up perfectly. They should just bolt in. There may be a little finessing with the antiroll bar linkage, but it shouldn't be bad.
Posted: Thu Jan 22, 2004 4:13 am
by LaureltheQueen
am I the ONLY one who finds it slightly amusing that subbies have BF and GF chassis'?
Posted: Thu Jan 22, 2004 7:55 pm
by JasonGrahn
yes
Posted: Thu Jan 22, 2004 9:38 pm
by DLC
Only a female would see that :D
Posted: Fri Jan 23, 2004 4:37 am
I would like to put the aluminum arms on the front and the trailing arms on as well. Prob won't happen until/when the whole drivetrain thing happens.
speaking of that.....Jason, any update from buckner?
yoyoyo
Posted: Fri Jan 23, 2004 6:04 am
by carfreak85
whats the deal with the trailing arms? They lighter or something?
Posted: Fri Jan 23, 2004 4:14 pm
all the alum pieces are a tad lighter...not much....but are stronger and have stiffer bushings.
hmmm
Posted: Sun Jan 25, 2004 2:52 am
by carfreak85
I thought that the only aluminum part was the lower control arm and the rest were steel. Is the suspension in the new GDB chassis all aluminum (besides the control arm)?
Posted: Wed Jan 28, 2004 7:56 am
by 970subaru
these aluminum control arms came on gc's stock? and all suspension pieces from a gc fit a 91 legacy? hot damn.
Posted: Wed Jan 28, 2004 8:05 am
by THAWA
No, I think they're aftermarket. STi or something, I haven't really been paying attention to them. Most suspension parts from a GC will fit on a BC since GC's use our chassis. The rear sway bar apparently has some problems with the fuel tank.
Posted: Wed Jan 28, 2004 8:15 am
Mine are STI units labelled for 'off-road use only'. I'm a rebel. I'll take my chances. But if they fail and I get hurt I won't sue!
Posted: Wed Jan 28, 2004 8:30 am
by THAWA
Some people have said they're stronger than the rest of the suspension, and if you hit a curb or soemthing you'll end up bending something else like crossmember or struts or something crazy, I wasn't paying much attention.
Posted: Wed Jan 28, 2004 8:49 pm
by 970subaru
yeh, if they are used for rally they damn well better be strong. but seriously... has anyone ever broken a control arm on their street car other than in an accident? aluminum control arms seems like a waste of $ to me, kind of like a $1000 titanium exhaust to save 3 lbs. theres other places your $ will go further.
Posted: Wed Jan 28, 2004 8:53 pm
by ciper
Forget the control arms. Spend the money on light wheight wheels which gives you less unsprung weight and less rotational weight AT THE SAME TIME!
Posted: Wed Jan 28, 2004 9:19 pm
I agree, there are better ways to spend money. I just got mine because they were real cheap. I've seen them for $1k and that's rediculous. For what I paid, you could almost buy two cheap wheels. I thought they'd look great too when approaching my car from the front as you can see the OEM arms quite clearly. I also want to replace the bushings and balljoints when I change the engine and the arms came with these installed.
Posted: Thu Jan 29, 2004 3:23 am
From what I heard, weight isn't that much less.....it's the strength of them. My reasoning to get them would be the bushings....however if I can buy the same bushings and install them on the current arms.....I'll just do that....I don't care.
Posted: Thu Jan 29, 2004 3:30 am
by ciper
If you got an ALK that would have new bushings, and in three different hardness. All you would need then is the front right?
Posted: Thu Jan 29, 2004 3:37 am
Yeah I think so....just that front bushing.
My only concern with the ALK is it takes the anti geometry out of the car and it will dive more under braking.....car already dives under braking....I really don't want more........that's been my only concern with putting an ALK on...
STi
Posted: Fri Jan 30, 2004 3:33 am
by carfreak85
These come stock on the STi. I have not seen these for more than $400 anywhere. Im gonna get them...
