FWD only curcit on 5spd Legacy L (92 wagon)
fotografer
Post by fotografer »
Might there be a similar function on the manual version? I know there is a fuse to activate FWD on the automatic, seems like there should be somethign similar on the AWD manual version. It would make putting the spare on not quite as frightening. Replacing a viscous coupler is a bit on the spendy side...
ciper
Post by ciper »
No such thing. The manual transmission on all cars 90+ are strictly mechanical, except the XT6 which had a lockable center diff.
nope, as mentioned......it's purely a mechanical design.....you can't disable it.
