Car Weight?
FAQs, community and board information.
Subleg4
Car Weight?
Post by Subleg4 »
I looked in my door jam today to see if it would tell me how much my car weighed, I saw 4110LB on there and was wondering if thats the weight for a 92 Turbo 5spd? Damn if it is i had to idea i was driving a tank around
92 Legacy Turbo 5spd, one of the privleged few!
"Its not the size of the dog in the fight, its the size of fight in the dog."
DLC
Post by DLC »
The door jamb has never stated the actual weight of the car. It does state the maximum recommended weight of the car plus passengers and cargo.
The 92 Turbo 5MT should weight around 3100lbs:
http://legacycentral.org/library/92_guide.htm
Legacy Central
Maybe you were looking at the gross vehicle weight rating? That's the maximum total weight (car plus cargo) that the chassis is rated for.
Though 4110 pounds doesn't seem like that much cargo, since I seem to remember Legacy sedans weighing around 3200 pounds.
ciper
Post by ciper »
Most smaller cars are rated to carry 8-900 pounds. 4110 - 900 = 3210?
Really? 900 pounds doesn't seem like very much. It seems like 4 grown-up men in the passenger compartment and their luggage in the trunk could easily exceed that.
ciper
Post by ciper »
Yup. Im pretty sure the 2003 is only rated at 1000 lbs, so imagine our soft chassis rating.
scottzg
Post by scottzg »
scottzg wrote: the number is the weight in pounds
fwd
base manual automatic
........2720......2820
L......manual automatic
.......2735.......2835
LS....manual automatic
.......2825......2925
LS2 manual automatic
......2830......2950
4wd
L.....manual automatic
......2925.......3005
LS...manual automatic
......3015.......2095
LS2..manual automatic
......3040........3120
These figures are straight from the 1990 fsm, which does not include the turbo model. I would guess a turbo model would be ~40 lbs heavier
do a search :wink:
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
I think the weight ratings are like elevator ratings (where each of the multiple cables can hold three times the rating) as my old rotted '84 was rated at 750lbs (before the rot), but I packed it with a few hundred pounds over that back and forth to Detroit running near redline through most of Canada and never had a problem. Also fit 13 kids in one time (this was high school), although I couldn't get over 25 mph.
scottzg
Post by scottzg »
i think the determining factor is the suspension. I know it doesnt take much to bottom out bmws. And they can't specify where you are loading your weight. Maybe you have a trunk full of rocks.
ciper
Post by ciper »
I think its the tires. Why do you think some trucks have duellies? It has nothing to do with traction, its because you cant get single tires to hold up the fully loaded weight.
I think its a combination of tires and suspension. To prevent bottoming out on the old car I got truck air shocks for the back (looked cool with the back jacked up anyway) and for the weight I fully inflated the tires. Don't do that in the desert, though - the heat will expand and can blow the tires out.
THAWA
Post by THAWA »
scottzg wrote:i think the determining factor is the suspension. I know it doesnt take much to bottom out bmws. And they can't specify where you are loading your weight. Maybe you have a trunk full of rocks.
I thought on the little plate in the door jam there was a rating for each axel and one more for the whole car?
Yes.
curb weight is the dry weight, and is what you posted scott.
gross weight is what the car is "allowed" to carry.
The actual weight will vary.
I weighed mine on truck scales. I posted something in one of the forums...don't remember which. Full tank of gas and me in there, my car weighed about 3100 lbs....that's with sub box too.
NICO
Post by NICO »
my LEAN legacy weighed 1300 k so in LBs its 2860lbs not bad but its still going on a diet.
Chi_San
Post by Chi_San »
Edmunds lists my 2000 Sedan at 3,200 lbs dry. I'll weigh it tomorrow and see what it actually weighs in at. :p I'll have to find a scale that's working, though. A lot of the local scales are out of order? :?:
90LegAWD
Post by 90LegAWD »
Legacy777 wrote:curb weight is the dry weight
FYI, curb weight is NOT dry. it includes all fuilds at nominal level
