TD05 on Ebay
TD05 on Ebay
Hey Guys,
Check it out...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2459072174
These turbos are great bolt on's for our engines!
Check it out...
Wow, I really wish I had the money to bid on that right now. Someone should jump on this!
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I have no idea, but it is very similar to the small 16G for DSMs. The compressor maps for the small 16G can be found in a google search.ciper wrote:What would be the maximum amount of boost possible (keeping in the eficient range) for this turbo on a 2.2 liter?
- Lurker-King
Which sucks b/c if Fredy wrx win it, you know he's gonna modify the turbo inlet, making it useless for any of us.
ciper, you better win this auction!!
You should try auctionsniper.com, if you really want to win it.
On a somewhat related note, does anyone know how easy it would be to swap an 18G compressor into the subaru TD05 housing? I know that the 18G is the largest compressor that can fit into the Mitsu TD05 housing.
- quasi-mod-o
I second this question? I was under the impression that the TD05 maxed out around 16-17. Anybody got anything in print, like a compressor map?ciper wrote:18 on the 2.0 liter?
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
http://www.graphics.cornell.edu/~v/comp ... glarge.gifMatt Monson wrote:Anybody got anything in print, like a compressor map?
http://www.graphics.cornell.edu/~v/comp ... gsmall.gif
I don't know which is the relevant one.
- quasi-mod-o
Um, can you help me out here? Maybe I am a little dense, but how does telling us the displacement of an EJ20 tell us the compressor efficiency of an TDO5?MY92 wrote:I answered the Q.MY92 wrote:Yep, 1994cc
![Question :?:](./images/smilies/icon_question.gif)
Suby Hai!
Suby Hai!
- quasi-mod-o
As usual vrg3, you deliver. I will run the numbers for myself...vrg3 wrote:http://www.graphics.cornell.edu/~v/comp ... glarge.gifMatt Monson wrote:Anybody got anything in print, like a compressor map?
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Suby Hai!
Suby Hai!
Use the small 16G compressor map.
Matt Monson, as for the efficiency being for a 2.0L, the rate at which a turbo operates is dependent on both displacement and pressure. Imagine if you will, two containers, one 2L and one 2.2L. The 2.2L obviously has more capacity. If you were to take two water pumps of the same size and try to fill up the containers completely in the same amount of time, the pump filling the 2.2L would be working "harder". The same holds true for a turbo, which tries to maintain the same pressure for both engines.
The turbo might be efficient on a 2L at 18psi, but 18psi on a 2.2L will be out of the effective efficiency of the same turbo, because it will be working harder to pressurize the larger engine at the same psi.
That's why whenever you ask someone what the efficiency of a turbo is, they'll usually tell you for a certain size engine.
- quasi-mod-o
Thank you. I was aware of the tech behind it and thus why I was more interested in the maps since I do know how to do this math myself. Knowing where the TD05 maxes out for an EJ20 does very little to help me verify the efficency for the EJ22.boostjunkie wrote:Use the small 16G compressor map.
I just couldn't figure out why MY92 felt the need to be so unhelpful with his responses.
Suby Hai!
Suby Hai!
