1994 Legacy Turbo with 4EAT
nsantos23
Post by nsantos23 »
Hi guys i'm back, this time with a 94 turbo auto, dammit i miss my 91 5spd!! anyways i need to find the 4EAT control box in the car, where is it located. the problem is that the power light on the dashboard keeps on blinking when i start the car for about 1 minute and then stops, but then again the tranny is been acting weird when shifting, is there any suggestions? should i clean the contacts on the wires on the tranny?
Thanks in advance
Neo :?
mTk
no title
Post by mTk »
The transmission computer is under teh driver's side dash right next to the steering column. I'll see if i can find a pic.
MK
1992 BC672 AWD 5MT
ciper
Post by ciper »
What will finding the computer help you do? Id search the BBS for how to retrieve errors from it.
Its the box right next to the stearing column with two 10mm bolts holding it to the body.
kyledooley
Post by kyledooley »
Do a search for the secret handshake with the key and the shifter to read to the codes. It will be a series of flashes on the power light.
Kyle
