Can you check tire pressure with unmounted tires?
I know this seems kinda silly, but I'm just wondering if this is one of those things that needs the full weeight of the car to be accurate.
tire pressure will be slightly different with the car's weight on them....maybe 1 psi or something......
rallysam
That's it? Wow, good to know. I never used to trust measuring them off the car but I guess I will try it from now on.Legacy777 wrote:tire pressure will be slightly different with the car's weight on them....maybe 1 psi or something......
'00 Impr RS - sold
