Suddenly my power seat belt retractors, power windows, and power door locks have failed. (60K) It seems each has its own relay so it seems highly unlikely that I would have 3 relays fail at the same time.
Anyone know of a common ground that I might check? Fuses look good under the hood and also under the dash...
Thanks for any assistence,
P
Electrical Gremlins- Help 93 Legacy AWD
you check your fuses?
