TD05H Wastegate Q's
Posted: Tue Feb 24, 2004 2:32 am
by LegacyT
Well, today I got my TD05H 16G off a 95 STi in the mail. It came without the wastegate. Is the wastegate specific to this turbo? Can I use an RHB5 wastegate or is that a no no? Could I get a dsm talon/eclipse TD05 Wastegate? Is the wastegate specific to the compressor? For example talons had 14G compressors, could I use the wastegate off that? Or must it be a TD05 16G wastegate?
Thanks,
Mark,
Posted: Tue Feb 24, 2004 3:25 am
by ciper
Well, if you cant figure this out how about an external unit?
Posted: Tue Feb 24, 2004 4:21 am
The plumbing for an external wastegate might counter the benefits of having a turbo with the same housings as stock.
Posted: Tue Feb 24, 2004 4:27 am
by volt
this is from rslibertycub.org
"Any engine running a TD05, or late model VF series turbo has a 9psi wastegate, where the early libertys run VF8/10/12 which is 6psi wastegate"
Posted: Tue Feb 24, 2004 12:18 pm
by LegacyT
The Legacy turbo is a VF11 right? so that no good??
Mark
Posted: Tue Feb 24, 2004 3:54 pm
Mark, I say just try to get any old wastegate actuator you can find and try to make it fit. I'm not qualified to make this guess, but I would guess that another FHI-housing turbo's wastegate would be easier to attach than that from a TD05 in a different housing.
The difference in spring stiffness shouldn't matter too much, since you're going to be using some kind of external boost control anyway, right?
Posted: Fri Feb 27, 2004 4:45 am
by legacy92ej22t
LegacyT wrote:The Legacy turbo is a VF11 right? so that no good??
Mark
The VF11 and the VF10 should have the same 6 psi wastegate. The only difference between the two is that the VF11 has a bigger compressor fan then the VF10.
They also both came on the Legacy turbo too.
Posted: Fri Feb 27, 2004 12:34 pm
by LegacyT
ya ythe legacy turbo came ith 10 and 11 compressors both 6 psi springs. The TD05H wastegate had a 9 psi spring. I think I'll just wait till a TD05 wastegate pops up instead of trying to make a difffernt one work.
Mark,
Posted: Sun Apr 04, 2004 11:36 pm
by DeadboltEnterprises
LegacyT wrote:ya ythe legacy turbo came ith 10 and 11 compressors both 6 psi springs. The TD05H wastegate had a 9 psi spring. I think I'll just wait till a TD05 wastegate pops up instead of trying to make a difffernt one work.
Mark,
Let me know if I can help you with anything. I think I have a used one of those laying around the garage somewhere. :)
Posted: Mon Apr 05, 2004 5:35 am
by morgie
The th05 and td04 seems to share the same wastegate actuator.
just go into a good performance shop, or turbo shop (for .. diesel truck and stuff) and ask for a replacement actuator for a mitsubishi td05.
a friend here got one for his td05.
