what does it take to install a wrx shifter on the legacy n/a
legacy32656
Post by legacy32656 »
i heard that it bolts right up. but the linkage is wrong?? what do i need to do to make it work?? will it be better then my org one?? i pay on adding a short shiffter on to it. let me know
thanks brian
pjgaerlan
wrx shifter linkage
Post by pjgaerlan »
If you go to legacycentral.org he used the spt short shifter. I think you need an adapter of some sort to make it work. There is a guy called Richard Buckner he is the parts guy at Royal Moore subaru in Oregon. He knows how to make the WRX shifter linkage work.
PJ
STi_GUY
Post by STi_GUY »
Better, although more costly, option. B&M makes a short shifter for our legacies. You can find it at the site in my signature. Its Teagues Auto in NC. It runs $199.
Cody
1994 Legacy Ti Wagon (Estate)
2.4L of N/A fury :)
Awesome vendor: http://home.att.net/~teaguesauto/index.htm
Brat4by4
Stratified
Post by Brat4by4 »
Is there any place to get all the replacement bushings? A short shift would be nice but I don't consider it a necessity. Knowing nothing about the shift linkage... is it even worth trying to replace bushings? Or is it better just to put another one in?
Post by entirelyturbo »
To answer your question, Brian, more work than I think it's worth...
viewtopic.php?t=367
*Formerly DerFahrer*
legacy92ej22t
Post by legacy92ej22t »
So just to clerify, the wrx shifter doesn't bolt on easily? I have a chance to get a wrx stock 5 speed shifter at a good price and was hoping it would work. I checked that other post and it said something about the knob not fitting. I just got a wrx aliminum momo knob and it fit fine on my legacy turbo shifter. Are the legacy turbo shifter the same as the n/a legacy? I've looked at the short throw at teagues and it's sweet but I don't have $199 to spend and need to address my sloppy ass shifter soon. What causes the shifter to get so sloppy? Is it the gear box, or shifter bushings or what? I'm not familiar with the manual setup at all (obviously) so some advice would be very helpfull.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Silly question. . . . but what if you've got a WRX tranny with an EJ20 under the hood?
Does the position of the shifter on the Legacy chassis present any linkage issues with the WRX tranny position in relation to it? :D
I know. . . WAY off-topic. :P
