new legacy pics before being sold :)
Yahtzee
Post by Yahtzee »
hi below some pics i forgot to post a while ago car is going to be sold soon end of legacy ownership after 5 years :) i know some people wanted pics of filter installs too :)
cheers
will
I especially like the engine turning on the air surround. Nice touch.
ciper
Post by ciper »
I like the cold air setup and the heat wrapped intake!
Using the air con cover over the alternator is a nifty idea.
The motul sticker though?! :x
Yahtzee
Post by Yahtzee »
:) can never have too much heat wrap too much hot air is not good :)
exhaust has proper wrapped open neck downpipe too :)
will
richieh
Post by richieh »
hi m8 i'm looking to do a similar setup on my estate with a k+n
what did u use for the intake pie between maf and turbo
cheers richie
Yahtzee
Post by Yahtzee »
hi
it was a samco type hose (about 45 degree angle on it)
plus a stainless steel tube of same dia that came with the filter
which i juggled about to make the angle from turbo to
position filter where i wanted it.
then plastic/nylon hose connections into samco for connecting pipes etc.
works spot on
will
EJ22E-94
Nice light....
Post by EJ22E-94 »
So you are in England?
Are you able to find the tail lights for me for in USA subaru?
I want the rear part so bad since I only see it once (well twice now), in US that another drive has the sam rear tail light and the trunk cover.
Let me know the price and the shipping. I have paypal and wiling to see if you can find it for me.
M
Current Bush administration exchange rates will kill you.
