Simple Mod Day
Simple Mod Day
So today I spent some time doing some simple mods. I slapped in a K&N filter which i've been meaning to do for a long time but haven't. I also cleaned out my IAC valve so tomarrow mornign I should know how well that worked. I also did the Throttle body bypass mod. The passenger side hose going from the IAC to the throttle body is really annoyingly short. It took a little bit of work to get everything hooked up, but I didn't break any hoses, lines or parts, so that is a big plus. I also capped the ends of the throttle body tubes with a rubber 1/4 in. vacuum plug. The 3/8 in. was just a bit too loose.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
http://bbs.legacycentral.org/viewtopic. ... tle+bypass
Basically there is a coolant line running through the throttle body. The mod basically take the coolant lines and connects them, bypassing the throttle body. It isn't recommended to do this in cold areas. But since I'm moving to California, and leaving Washington, I figure it is a safe time to do it.
2014 Volvo S60 T5
2014 Volvo S60 T5
You should be able to do it easier than me. I had a bunch of turbo lines and things I had to move to get to it. I also pulled the throttle body. I found it easier. I haven't noticed much of a difference yet, but that may change as I drive it around more. I hear the biggest thing is throttle response.
2014 Volvo S60 T5
2014 Volvo S60 T5
