How many horses, mbc?
how much of a horse power gain will i get if i get a boost controller and run 11psi, i have everything stock except the exhaust and intake.
92 legacy turbo 5spd fwd-12 psi, tm intercooler bov, walbro 255.
81 chevy malibu- 400 sb, holley 600, edelbrock rpm, hooker headers, lunati voodoo cam,4spd muncie, 3:73 posi,monte c. swivel buckets, corvette rally wheels
I believe that is a rough estimate, dependent on the type of turbo. As long as you stay within 70% of the turbo's efficiency range, and the inlet temps don't rise to dramtically (considering you don't have an intercooler), you'll see an increase.
I would honestly open up the exhaust before you go with more boost, considering that's probably a huge restriction.
Speaking of the efficency range. What is the PSI that the VF-11 is most efficent at?boostjunkie wrote:I believe that is a rough estimate, dependent on the type of turbo. As long as you stay within 70% of the turbo's efficiency range, and the inlet temps don't rise to dramtically (considering you don't have an intercooler), you'll see an increase.
98 LGT
I think that is incorrect. The optimum pressure at 14.7 PSI atmospheric pressure is +14.5 manifold pressure.
Once you reach 10 thousand feet the turbo is only efficient to 10.4 PSI.
You have to take elevation into consideration. Subaru chose a pressure that could be compatible for the entire range of operating enviroment.
Here's the topic you're thinking about ciper
http://bbs.legacycentral.org/viewtopic.php?t=14816
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
truck intercooler yes and the motor just blew up at 500thosuand ks i got it with 179ks the best motor subaru makes, it can with stand a beatting its a real rally motor.
I bought a Turbo XS standard MBC. with bypassing the controll solenoid and taking the bleeder valve out (thats how the standard ones work. no restrictian) All I could get the car to run was about 11 to 12 psi at full throttle. If you are on it with just partial throttle than it can raise to about 15 psi. so a boost gauge would be helpful. But if you get a standard controller from them, and back off the valve all the way, you should get the boost you want. those 2 psi make a big difference. one more psi makes an even bigger difference. My car runs great with 13 psi.
Yellow '01 Kaw. ZX-7R (SOLD) :(
Gold '88 Starion ESI-R (Drift Project)
Brgndy '92 Legacy SS, Agency Power Style Headers and Up-pipe (ebay, don't stay together), Underdrive Pully, 5MT conv, mod'd WRX cold air intake and short shifter, 12.5 lb fly
the reason you only get 12 PSI at full throttle and 15 PSI at full throttle is because of your boost controller.
You are bleeding off too much pressure, and the Wastegate actuator does not have enough pressure holding it closed. So what's happening is the exhaust gases are blowing the wastegate open at full throttle.
You can do a couple things...you can throw some springs on to hold the wastegate rod closed, or figure out another Boost Controller method
i agree turbo xs does not make good boost controlers. i have the dual stage one and the single one and i could not get past 15psi and it was to hard to set. get hks products the best u can bye
