For some reason I thought that the ej22t came stock with a type of steel sleeve on the inside of the cylinders....I was just told from an owner that he knew nothing about this...
(I had previously asked him about his decision in boring out the cyldinders if this would eliminate this imaginary steel sleeve)
Will someone confirm for me that this sleeve doesn't exist? Also...if not, has anyone heard of experimentation with this?
jason
Steel cylinder wall lining?
