Anyways, I had been getting a pulse and shudder when braking at higher speeds over the last month or two, with it getting especially bad over the past few weeks. I figured I warped the hell out of my front rotors and wasn't really too concerned because I have a new set of Mountain front rotors waiting to go in and I planned to swap when the weather would cooperate.
Well I went ahead and changed over to my summer wheels recently and figured I'd take a quick look at my front brakes to see what was going on but not swap yet because I didn't have the time. I didn't notice anything obvious but my driver side axle nut caught my eye because it had come unstaked! I go to look at it and I could turn it with my fingers!
I tightened it down, restaked it and went for a drive. The brake shudder was almost completely gone. Since I've still got a little shutter when braking from higher speeds I figure that the problem caused my front rotors to warp slightly or I cooked my wheel bearing
I guess the moral of the story is that when you experience brake shudder and pulsing in the pedal, check your axle nuts too. It could be the problem.
