Checking out legacycentral in search of the gear ratios in my turbo, I came across this:
http://legacycentral.org/images/93_pack ... pecs_1.jpg
Is that right, even for the turbo cars? Is our final drive really 4.11 with the 5MT? Are the ratios the same between the N/A and the Turbo cars?
And that picture says the compression ratio for the SS is 8:1, I thought I read somewhere that it was 8.5:1?
All of the specs for the 93 Sedan should be the same for the 94 Sedan right?
Tranny ratios for the 5MT Turbo?
Re: Tranny ratios for the 5MT Turbo?
The compression is 8:1.BAC5.2 wrote:Checking out legacycentral in search of the gear ratios in my turbo, I came across this:
98 LGT
All turbos are 3.9.
All EJ22Gs are 8:1 CR.
Legacy Central
