ok i want some theories...
I have had this whine coming from the rear of my car for some time now. It only happens when I'm traveling between 55-75mph. I thought it was either the rear differential, drive shaft, or something bearing related(half shaft?). Just the perfect pitch for some sort of resonant and boy is it annoying!
Then suddenly one day it disappeared. It happened right after I rotated the tires. I was like, all this time, the tires weren't the same size and was causing the noise. But 5 days later the noise came back! Those particular days that it wasn't making any noise was due to the extra 200lbs+ i had in the back.
so any guesses to what i should look at first?
lex
http://lexinator.com/cars/legacy
whine theories
the real answer!
wow i'm disappointed that no one had a single theory...
well all of them would have been wrong!!! it turned out to be my roof rack. I still haven't pin pointed the exact source on the roof rack itself, but damn was it annoying and ridiculously loud.
It took me a while before I (actually my girlfriend) determine where the noise had been coming from...
lex
lex
Wow, so it was wind noise?
Maybe you could get a wind deflector to go at the front of the roof rack.
Did you install the rack yourself? Sometimes if installed facing backwards roof racks can make a lot of noise.
